Page 112 of 295 FirstFirst ... 1262102107108109110111112113114115116117122162212 ... LastLast
Results 1,666 to 1,680 of 4423
Thread: VVDI PROG
  1. #1666
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Some pic from Siemens ECU for use all
    Not : in all Siemens ECU cut pin 18 AMIS IC or
    Pin 1 L9613
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  2. The Following User Says Thank You to CarCity For This Useful Post:
    rob h (15th November, 2017)
  3. #1667
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    And Siemens - Continental gear ECU
    C5 - 206 - 407 - ...
  4. #1668
    Apr 2015
    Quote Originally Posted by valdirld View Post
    i tryed to read EMS3134, says chip not conect, try read ME 7.4.4, same problem, cannot read anny ecu that uses 29fxxx, wath can be wrong?
    friend, please check your device adapter whether inside wires connection good as sample photo.
    if check same but still cannot read let me know.
  5. #1669
    Sep 2015
    Botswana
    hie samic
    i am trying to read immobilizer for jeep with immo box 5wy7 005c with masket 0j66d but i cant manage its giving me an saying chip unconnected.
  6. #1670
    Apr 2015
    Quote Originally Posted by LEORNARD NKATA View Post
    hie samic
    post your connection wires here, will check for you.
  7. #1671
    Apr 2015
    Quote Originally Posted by automotrizVIP View Post
    I'm ready to try it :-)....
    SAK-C167CS-AM29 beta version download link:
  8. The Following 3 Users Say Thank You to Samic For This Useful Post:
    habbyb (16th November, 2017), keyantic (16th November, 2017), valdirld (27th November, 2017)
  9. #1672
    Sep 2015
    Botswana
    Quote Originally Posted by Samic View Post
    here is the connection wires diagram
  10. #1673
    DK Veteran labusas's Avatar
    Nov 2010
    Mine was update, is it still a correct way like in my pic? or should I go back to what in you post Samic?
  11. #1674
    Jan 2010
    .....Thanks
  12. #1675
    sniegavirs's Avatar
    Mar 2017
    Latvia
  13. #1676
    sniegavirs's Avatar
    Mar 2017
    Latvia
    You should practice more with soldering. That red wire soldered to the chip can make a lot of things not happening..
    Quote Originally Posted by labusas View Post
  14. #1677
    Mar 2017
    Colombia
    I assault copper tip 5 cm...with insulation to avoid contact between them, only the tip use.to facilitate a better contact for better precision
    WINNER THE LOSER
  15. #1678
    Mar 2017
    Colombia
    Today I'll start ... but I have only 2 versions
    WINNER THE LOSER
  16. The Following User Says Thank You to automotrizVIP For This Useful Post:
    Gioaute (17th November, 2017)
  17. #1679
    Faraday's Avatar
    May 2012
    The dark side of the moon
    I bought vvdi prog, but I'm disappointed right now. For example v850 d70F3629 I can't read it but uusp on the same pinout read ok (I use mcu reflash cable V3 like on manual)
  18. #1680
    Nov 2012
    Mate. You never have enough programmers.
    Upa, orange, smok Jtag, vvdi, r270, x-prog, necprog, 35080 eraser, etc.
    They all have goods and bads...
  19. The Following 2 Users Say Thank You to dorofteius For This Useful Post:
    eliaselias (19th November, 2017), habbyb (19th November, 2017)
