Just received my adapter sets from sugar xhorseshop, and had a play with vitto w639, read st in 20 sec, wrote new file in under a minute,they seem to be well made. watch out there are 2 adapter sets for these! I used 0L02M (adapter) from the menu.
p1et (28th March, 2018)
I try many time not success it have error cpu not connect
will try again today
thank
have error
[2018-03-29 19:13:12] : Change to 2-MCU-->RENESAS-R8C-->R5F21548G
[2018-03-29 19:13:14] : Select <D-FLASH>
[2018-03-29 19:13:22] : Select <D-FLASH>
[2018-03-29 19:13:29] : Check Device...
[2018-03-29 19:13:30] : 12V Power Adaptor connected
[2018-03-29 19:13:30] : Initialization device...
[2018-03-29 19:13:32] : Initialization success!
[2018-03-29 19:13:33] : Initialization chip...
[2018-03-29 19:13:35] : Try Security Bytes 00000000000000
[2018-03-29 19:13:35] : Security pass success
[2018-03-29 19:13:35] : Start communication...
[2018-03-29 19:13:35] : Read length:0x1000
[2018-03-29 19:13:35] : Reading...(0%)
[2018-03-29 19:13:35] : Read Error
try Erase no problem
2018-03-29 20:25:34] : User select yes
[2018-03-29 20:25:34] : Check Device...
[2018-03-29 20:25:36] : 12V Power Adaptor connected
[2018-03-29 20:25:36] : Initialization device...
[2018-03-29 20:25:36] : Initialization success!
[2018-03-29 20:25:37] : Initialization chip...
[2018-03-29 20:25:38] : Try Security Bytes 00000000000000
[2018-03-29 20:25:38] : Security pass success
[2018-03-29 20:25:38] : Start communication...
[2018-03-29 20:25:38] : Erase length:0x1000
[2018-03-29 20:25:38] : Erasing...(0%)
[2018-03-29 20:25:38] : Erasing...(25%)
[2018-03-29 20:25:38] : Erasing...(50%)
[2018-03-29 20:25:38] : Erasing...(75%)
[2018-03-29 20:25:39] : Erasing...(100%)
[2018-03-29 20:25:39] : End communication...
[2018-03-29 20:25:39] : Operation success
And try write it no problem
[2018-03-29 20:27:04] : Start communication...
[2018-03-29 20:27:04] : User select yes
[2018-03-29 20:27:04] : Erase length:0x1000
[2018-03-29 20:27:04] : Erasing...(0%)
[2018-03-29 20:27:04] : Erasing...(25%)
[2018-03-29 20:27:04] : Erasing...(50%)
[2018-03-29 20:27:04] : Erasing...(75%)
[2018-03-29 20:27:04] : Erasing...(100%)
[2018-03-29 20:27:04] : Write length:0x1000
[2018-03-29 20:27:04] : Writting...(0%)
[2018-03-29 20:27:05] : Writting...(25%)
[2018-03-29 20:27:05] : Writting...(50%)
[2018-03-29 20:27:05] : Writting...(75%)
[2018-03-29 20:27:05] : Writting...(100%)
[2018-03-29 20:27:05] : End communication...
[2018-03-29 20:27:05] : Operation success
have solution?
thank
Originally Posted by automotrizVIP
hello friend @samic any chance to add this type of reference with proper reading
Ecm Renault.....
Renault
Valeo V40/V42 (SH7058/1024KB)
Sagem 3000 (SH7055/512KB)
EMS3110 (TC1766/1504KB)
Logan, Sandero, Fluence, Megane, Almera EMS3120 (TC1738/2048KB)
Duster, X-Ray EMS3125 (TC1782/2560KB)
Clio 4 1.6T EMS3150 (TC1767/2048KB)
Reading, writing, checksum correction.
Bmw eeprom soic 8
Eeprom 160DOWT ....
Thank you
@Samic
My company has 10000+ different ECU and modules in stock, if you want anything we have in stock I can send to you for your testing purposes. Feel free to send me a Skype/pm and I will happily oblige.
Always happy to help where I can
automotrizVIP (30th March, 2018), cfgebel (31st March, 2018), habbyb (1st April, 2018), Samic (31st March, 2018), u.s (31st March, 2018), vasiliev7719 (2nd April, 2018)
Anyone have any pointers for me, i'm trying to read a MC68HC05E6 (0F82B) on a PSA immobox (Siemens), Part number: 9629677480
When i try to read the chip it'll show initialise success, shows 0% and then read error.
Even tried removing the chip from the PCB and get same results (but maybe this chip needs to have the external oscillator circuit).
There doesn't seem to be any option in the software to change the frequency.
I'm using the V3 MCU cable, and latest software. Connections to the chip as per diagram in vvdi-prog software - checked & double checked
Thanks in advance
hi
bmw f10 2010 cas 4 5m48h BACKUP dflash I read all FF . what it is possible to make??
Double post
+thanks if I helped you!
no, other programmator I didn't try, p-flash was read normally, and d-flash one ff
it is possible to make that worked with other cas4?? except purchase of new cas4 from the dealer
I read isn with ecu msv90, still there is a suspicion that p-flash too bad
prompt marking of the diode a photo it is specified by an arrow, and can eat at whom d-flash and p-flash from this cas4
WRX 14 (2nd April, 2018)
