Page 168 of 295 FirstFirst ... 68118158163164165166167168169170171172173178218268 ... LastLast
Results 2,506 to 2,520 of 4423
Thread: VVDI PROG
  1. #2506
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Did few cas 3+ no problem.
  2. #2507
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    I made lots of CAS3 and CAS3 + with Vvdi prog and never in any case had problems ...
    Solutions in the area of automotive coded keys, all automakers.
  3. #2508
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by hipolitogt View Post
    Did it too... And no problem, and the cas4 was from my car and has the worst scenario possible: I had to cut the pcb and the restore it, and my car keep going...
    Enviado desde mi SM-G960F mediante Tapatalk
    Anyone tried read CAS4 version which VVDI tell us to cut track but actually without cutting them? In the past I heard someone tried and all was fine but I wonder if he got luck or cutting track is actually not neccesary. Some programmers does not require this.
  4. #2509
    pierre renault
    Guest
    Hi VVDI PROG has function (calculator) to change KM in CAS, or just read and write MCU?
  5. #2510
    ttzag's Avatar
    Jun 2010
    digital-kaos
    Quote Originally Posted by pierre renault View Post
    Just read and write
    Sent from my HTC U11 using Tapatalk
    Actions speak louder than words
  6. #2511
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mates,
    I´m thiking to buy this programmer. Can anyone share manual to check all the memory it can read? I tried to find by internet but I didnt find pdf with all the info.
    Thanks in advance
  7. #2512
    pierre renault
    Guest
    ttzag...............
    just read and write ?? and how do I change 125777 to 88345 ????
  8. #2513
    Jul 2018
    Hello ,
    Please how to virgin PCF7961 With VVDI PROG I Don't Have the File for virgin or Only make Reset Protect ?
  9. #2514
    Poland
    reset to 0 in readed dump and write resetted dump
  10. #2515
    Mar 2017
    Poland
    Hi. I've got problem with reading 93s66. When I use EEprom adapter reading is all FF. When trying with EEprom clip adapter then all is 00. With clip i don't use probe. I don't know how to use it. It's from E46 and E39 dashboard. 93c46 from E36 was ok with clip.
    Is it necessary to choose right producer of the chip or only type of memory?
  11. #2516
    May 2010
    Quote Originally Posted by lukasz61 View Post
    this is a operator error and not the device.
    to start with that you have mounted the eprom wrong on the board!
  12. The Following User Says Thank You to vageric For This Useful Post:
    mickye_dj (22nd September, 2018)
  13. #2517
    Feb 2014
    Yep! Do you see the little white dot on the PCB?
    And do you see the little dent on the EEPROM?
    Ok, now put the EEPROM so that both marks are together.
    Two more notes - yes, make sure you have chosen the correct EEPROM manufacturer from the VVDI menu. It may not be important for other programmers like UPA but for this one it matters!
    And make sure you have removed the correct EEPROM from the IMMO!
  14. The Following User Says Thank You to autoTkey For This Useful Post:
    lukasz61 (21st September, 2018)
  15. #2518
    Mar 2017
    Poland
    It's from instrument cluster, not IMMO. Can you help with choose right memory? It's 81AB B58 608. So it's 93s66 or 93c66? What manufacturer?
  16. #2519
    Feb 2011
    PL
    B58608 EEPROM 93C66. Turn the eeprom 180 degrees.
  17. The Following User Says Thank You to sqlkarol For This Useful Post:
  18. #2520
    Mar 2017
    Poland
    I will try later. Will report.
    Thanks!
