Any one know if we can renew remote key psa with PCF7945A / HITAG 2.
It's used on picasso, 308 II...
Any virgin file?
Also I need the same remote shape with PCF7953 / HITAG AES
it's used on 3008 II, C3 III...
With Tapatalk
vvdi prog can not even read 35160 with clip adapter?
I have only Vvdi prog at this time.
With Tapatalk
hi, airbag toyota 89170-0D590 RENESAS R5F61725
trying, read id receives an error
try frequency failed
maybe someone has a good pinout
Hi all
i use 4.8.3 software, device firmware is 2.0.0 when i try to update the firmware it never gets the link. How can i update firmware manually ?
Does anyone have pinout for E39 dash?
Sent from my MI MAX 3 using Tapatalk
comizelu (16th June, 2019)
hi freind price pls
any one have problem writing 95080 eeproms?
reading ok writing no ok
any fix for this
thank you
comizelu (19th June, 2019)
Did you erase it first?
https://www.digital-kaos.co.uk/forum...=1#post3568591
Anyone tried this solution by setting voltage to 3.3V and without cutting any tracks? Everywhere I see users say that with UPA it's safe to read with 3.3V so I think shouldn't be a problem with vvdi or xprog with those setting?
lets go scripting with vvdiprog
automotrizVIP (25th June, 2019), datapage (29th June, 2019), milehighlockdoc (25th June, 2019), Mingaz (27th June, 2019), rola1971 (11th July, 2019), sniegavirs (22nd June, 2019), zalimhan74 (30th March, 2024)
