Page 224 of 295 FirstFirst ... 124174214219220221222223224225226227228229234274 ... LastLast
Results 3,346 to 3,360 of 4422
Thread: VVDI PROG
  1. #3346
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by lidons View Post
    ERROR DO NOT read EPP 1L59W MC9S12DT128 MB EZS W209, Xprog Ok
    I have read this same memory in ELV A6 and CIM opel.
    any error with EZS ??
    I don't think it's vvdi problem. Did you tried to read other MCU's after it failed? Because I suspect maybe cable faut - might be broke somewhere, it happens.
  2. #3347
    Feb 2013
    UK Bristol
    Hi there lads. Dont sure which version software you use but on 4.8.8 maybe is some bugs. Yesterday i tried renew remote key for Opel Corsa D equipped on PCF7961 and write file is error with version 4.8.8.. with 4.8.7 all fine without any issue. So i recomended you maybe try diffrent version program.
    My post helps you? Please Hit Buttons
  3. #3348
    Aug 2009
    Quote Originally Posted by phatty123 View Post
    what year car? seems later models it cannot do
    2009 Passat with BZB-Enginecode
  4. #3349
    Jul 2009
    anyone else had the new versions of vvdi prog get exe file deleted windows defender, it was fine until a recent update from microsoft
  5. #3350
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by figani View Post
    I THINK 4.8.8. is lastest version...
  6. #3351
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Hello I tested the new option cas4 (read/write) without removing components on a cas4 5M48H and 1N35H but it didn't work, crack error. I heard some people don't have a problem with this, is this a hardware fault? Or does my unit need a update?
  7. #3352
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mates,
    Can anyone help reading 70F3380 on this sam from mercedes W204?
    thanks a lot
  8. The Following User Says Thank You to alclot For This Useful Post:
    Meat-Head (9th December, 2019)
  9. #3353
    hivrich's Avatar
    Sep 2012
    Ukraine
    Solved problem.............
  10. #3354
    pepi's Avatar
    Jan 2010
    Quote Originally Posted by drpeter View Post
    Did you try to remove capacitor in your case.
  11. #3355
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by pepi View Post
    No not yet but i heard people are doing it without removing the capacitor.
  12. #3356
    ghostrider72's Avatar
    Jul 2012
    UK
    No need to remove that
  13. #3357
    p1et's Avatar
    Oct 2013
    Need to remove if cannot crack without removing. Manual clearly say that. Me and my friend tested 5m48h and didn't work without all component in place but worked after desoldering 1 resistor.
  14. The Following User Says Thank You to p1et For This Useful Post:
    drpeter (9th December, 2019)
  15. #3358
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Default VVDI PROG
    Hi friends
    I have a problem with : MAC7242VAF64 in KIA Sorento Airbag unit ..
    Wiring some as VVDI-Prog user manual ( I didn't understand where the 12V written on the map should be connected ??)
    Read : OK
    Erase+Unlock : OK
    Write : OK
    Verify : NOT OK
    I try by any version but result some , dump verify is different , I appendix log file
    Thanked for any help
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  16. #3359
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by CarCity View Post
    Hi friends
    Read : OK
    Erase+Unlock : OK
    Write : OK
    Verify : NOT OK
    Try
    1. Apply external 12V to the VVDIProg
    2. Apply external 12v to the airbag ECU (remove 5v to VVDIProg to the processor)
  17. The Following User Says Thank You to hivrich For This Useful Post:
    CarCity (15th December, 2019)
  18. #3360
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Solved ...
    For write new file no need Erase + Unlock only load dump and write so verify success
