Page 254 of 295 FirstFirst ... 154204244249250251252253254255256257258259264 ... LastLast
Results 3,796 to 3,810 of 4423
Thread: VVDI PROG
  1. #3796
    Jun 2010
    EU Romania
    Quote Originally Posted by ALBERTO_ View Post
    Hi. I am reading the comments of the battery, I wonder if anyone has tried:
    1. Connect the equipment to the usb port and change the battery.
    2. Connect a second battery in parallel and replace the original battery.
    Regards.
    Alberto
    Need to work 100%, but you need to work with big precision to not make short circuit on pcb or anothers mistakes !
    If open the device and solder on pcb to connect in paralel second battery in some test points which go at - and + of ori battery, after you can unsolder safe the ori battery and replace it with new one or with new one with more capacity if fit in the sampe position in pcb to solder it, after can remove the second battery what it was solder in paralel for not lose the voltage when replace the ori battery, for not lose the data licence what have the tool !
    This metod need to work for all device what have RTC with battery inside and need it to be replaced at some time the battery, like for: VVDI Prog, VVDI2, FVDI, AVDI, SMOK, Iprog Pro, ....
  2. #3797
    s qubiak's Avatar
    Jun 2017
    Polska
    Opel Insignia 2011 year
    Body r/w vvdi prog
    pinout for all DK
    Mask 2M42E
    MC9S12XDG128MAL
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
  3. The Following 11 Users Say Thank You to s qubiak For This Useful Post:
    alclot (15th July, 2021), brane0001 (19th September, 2021), brodaty (30th August, 2021), danielif (30th July, 2021), dawidhubert (9th August, 2021), daxxer (2nd August, 2021), duzi (14th July, 2021), habbyb (16th August, 2021), lock66 (23rd August, 2021), ricked (16th July, 2021), scotlock (14th July, 2021)
  4. #3798
    s qubiak's Avatar
    Jun 2017
    Polska
    Opel Insignia
  5. The Following User Says Thank You to s qubiak For This Useful Post:
    Botos Leonardo (14th July, 2021)
  6. #3799
    Aug 2015
    GB
    Ford/Volvo i TC222 SRS- yes working
  7. #3800
    Mar 2010
    Timisoara
    Hello
    Regarding TC222 SRS
    Change to 2-MCU-->INFINEON-TC2XXX-->TC22X-16F
    [2021-07-16 11:53:14] : Change to <DFLASH>
    [2021-07-16 12:02:28] : Change to <DFLASH>
    [2021-07-16 12:02:29] : Change to <DFLASH>
    [2021-07-16 12:02:49] : Check Device...
    [2021-07-16 12:02:50] : 12V Power Adaptor unconnected
    [2021-07-16 12:02:50] : Initialization device...
    [2021-07-16 12:02:54] : Initialization success!
    [2021-07-16 12:02:55] : Initialization chip...
    [2021-07-16 12:02:55] : VCC setting error
    [2021-07-16 12:03:13] : Check Device...
    [2021-07-16 12:03:15] : 12V Power Adaptor unconnected
    [2021-07-16 12:03:15] : Initialization device...
    [2021-07-16 12:03:15] : Initialization success!
    [2021-07-16 12:03:16] : Initialization chip...
    [2021-07-16 12:03:16] : VCC setting error
    [2021-07-16 12:03:34] : Check Device...
    [2021-07-16 12:03:36] : 12V Power Adaptor connected
    [2021-07-16 12:03:36] : Initialization device...
    [2021-07-16 12:03:36] : Initialization success!
    [2021-07-16 12:03:37] : Initialization chip...
    [2021-07-16 12:03:37] : VCC setting error
    [2021-07-16 12:04:35] : Check Device...
    [2021-07-16 12:04:36] : 12V Power Adaptor connected
    [2021-07-16 12:04:36] : Initialization device...
    [2021-07-16 12:04:36] : Initialization success!
    [2021-07-16 12:04:37] : Initialization chip...
    [2021-07-16 12:04:37] : VCC setting error
    [2021-07-16 12:04:43] : Check Device...
    [2021-07-16 12:04:45] : 12V Power Adaptor connected
    [2021-07-16 12:04:45] : Initialization device...
    [2021-07-16 12:04:45] : Initialization success!
    [2021-07-16 12:04:46] : Initialization chip...
    [2021-07-16 12:04:46] : VCC setting error
    [2021-07-16 12:04:48] : Check Device...
    [2021-07-16 12:04:50] : 12V Power Adaptor connected
    [2021-07-16 12:04:50] : Initialization device...
    [2021-07-16 12:04:50] : Initialization success!
    [2021-07-16 12:04:51] : Initialization chip...
    [2021-07-16 12:04:51] : VCC setting error
    [2021-07-16 12:04:56] : Check Device...
    [2021-07-16 12:04:58] : 12V Power Adaptor connected
    [2021-07-16 12:04:58] : Initialization device...
    [2021-07-16 12:04:58] : Initialization success!
    [2021-07-16 12:04:59] : Initialization chip...
    [2021-07-16 12:04:59] : VCC setting error
    [2021-07-16 12:05:01] : Check Device...
    [2021-07-16 12:05:03] : 12V Power Adaptor connected
    [2021-07-16 12:05:03] : Initialization device...
    [2021-07-16 12:05:03] : Initialization success!
    [2021-07-16 12:05:04] : Initialization chip...
    [2021-07-16 12:05:04] : VCC setting error
    [2021-07-16 12:08:21] : Change to <DFLASH>
  8. #3801
    Mar 2010
    Timisoara
    Quote Originally Posted by andre1234567890 View Post
    what airbag type you read i try to read TC222S-16F133FAB ford transit JK2T-14B321-AG
  9. #3802
    Mar 2010
    Timisoara
    double post get used
    i try to read 80pin mcu
    just have to lift pin 68
  10. #3803
    Aug 2015
    GB
  11. #3804
    Jan 2021
    Hello , need an info pls , for vvdi prog sell an eeprom clip adapter.
    What is the use of it and how connect it?
  12. #3805
    Aug 2015
    GB
  13. The Following User Says Thank You to andre1234567890 For This Useful Post:
  14. #3806
    Aug 2015
    GB
  15. The Following User Says Thank You to andre1234567890 For This Useful Post:
    butugan_mihai (9th September, 2021)
  16. #3807
    Apr 2021
    hi
    having problem to read eprom st 95256wt with eprom solder adapter v2.0 . Eprom is from a bmw fem unit.
    had som other eproms i also couldnt read. just get message chip not connected.
    if put the v2.0 adapter in my orange 5 it reads without problem.
    anyone experienced this ? could there be something wrong with the vvdi prog ?
    Anyone? Still wont read 95xxx eproms.
  17. #3808
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    VVDI Prog
    v5.0.5 (2021-07-29)
    * This version DON't need update
    firmware
    + Add MPC5632M,
    MPC5633M,
    MPC5634M,
    options in
    <2-MCU>-><MOTOROLA-MPC563X>
    + Add CR16MCS9V,
    CR16MCT9V,
    options in
    <2-MCU>-><NATIONAL>
    + Add R7F701417,
    R7F701437,
    R7F701441,
    R7F701442,
    R7F701461,
    R7F701462 options in
    <2-MCU>-><RENESAS-RH850>
    + Add BUICK-REGAL-BCM(MC9S12XDP512)
    option in <4-IMMOBILIZER>-><BUICK>
    + Add S350 SRS(CR16MCT9VJE7)
    option in <7-AIRBAG>-><BENZ>
    many thanks to friend kevfield
  18. The Following 9 Users Say Thank You to daxxer For This Useful Post:
    amaflo (30th July, 2021), brodaty (5th November, 2021), dawidhubert (31st July, 2021), habbyb (16th August, 2021), HAMIZA (24th September, 2021), hivrich (31st July, 2021), KADE007 (30th July, 2021), rob h (12th August, 2021), ruemzaigc (2nd August, 2021)
  19. #3809
    s qubiak's Avatar
    Jun 2017
    Polska
    SRS Temic
    Old BMW E39
    mcu 912B32 R/W vvdi prog
    pinout all DK
  20. The Following 3 Users Say Thank You to s qubiak For This Useful Post:
    dawidhubert (27th October, 2024), daxxer (2nd August, 2021)
  21. #3810
    Aug 2021
    • 是的,我可以从中国寄给你
