Yes its third generation as of 2018
Sent from my SM-A125F using Tapatalk
Will someday add Micronas to read? Or is it going to be impossible due to the hardware limitation of the VVDI PROG?
My firmware had a problem. Someone would have a solution. Please?
The security chip in your vvdiprog called DALLAS is only storing the secu data when power is present. If it's lost then the DALLAS is going empty and your prog flip to "unsecured state" and no more working. Thats why a big backup battery soldered on your prog pcb. If your backup battery is depleted or faulty OR thats the main reason:
When you plug the usb port and the power comsumption is little bit bigger (like you attached some adpter to the vvdiprog too) or the backup battery is aging, or your laptop usb is not working very well...etc If this conditions are met the the power is lost (even is just milliseconds) and the Dallas is going empty.
The only solution when you asking your reseller to refurbish your prog. Bcose it's the very basic security programming stuff they have to send back your prommer to china.
Unfortunetly it's a very common problem in the automotive diag/etc industry. (cgdi, vvidi, smok..etc) For me the whole concept is inexplicable. They know the DALLAS need continous power and they are know the backup batterys are going bad sometimes, this simple led to extra work, time, shipping and bad reputation especially when far more better security solutions are available.
Sir, are you classified as human? Negative, I am a meat popsicle
ProblemChild (5th November, 2023), taxo1965 (18th January, 2022)
Bosch
VW Radio LOW EU UP2 BXV
1K0 035 186 AN
815 7 640 211 360
Made in Portugal
IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
RCD 310 .
Connect external 12V
Radio OFF.
bersch8688 (16th January, 2022), danielif (15th January, 2022), dawidhubert (21st January, 2022), hivrich (15th January, 2022), miroopel (15th January, 2022), rafal (15th January, 2022), spacer73 (16th January, 2022), ttzag (13th February, 2022), vas100 (15th January, 2022)
v5.1.1 (2022-01-24)
* This version DON't need update firmware
>>>DOWNLOAD<<<
* Modify LOCK_BCM2-1(ADAPTER), LOCK_BCM2-1(WELD),LOCK_BCM2-2(ADAPTER),LOCK_BCM2-2(WELD), options in <4-IMMOBILIZER>-><AUDI>:Optimize the process
* Fix DSM(2M25J/3M25J) diagram in<8-OTHER>-><BENZ>
* Add <9-TEST>-><TEST_FUNCTION>
+ Add MB91F522, MB91F523, MB91F524, MB91F525, MB91F526,
MB91F725, MB91F775, MB91F777,options in<2-MCU>-><FUJITSU-MB9XF>
+ Add TC21X-8F(JTAG), TC22X-12F(JTAG), TC22X-16F(JTAG), TC23X-16F(JTAG),
TC23X-24F(JTAG), TC23X-32F(JTAG), options in <2-MCU>-><INFINEON-TC2XXX>
+ Add XC2336A-72(JTAG), XC2336B-40(JTAG), options in <2-MCU>-><INFINEON-XC2XXXX>
+ Add SPC560P34, SPC560P40 options in <2-MCU>-><ST-SPC560XXXX>
+ Add JIEFANG J6(R7F701441) option in <5-DASHBOARD>-><FAW>
+ Add INSIGNIA AIRBAG(SPC56AP54) option in <7-AIRBAG>-><Opel>
+ Add BYD G3 ESL option in <8-OTHER>-><BYD>
+ Add CT6 option in <8-OTHER>-><CADILLAC>
+ Add X.E.N.I.A S80 BCM(SPC5602BXLQ) option in <8-OTHER>-><FAW>
amaflo (25th January, 2022), brodaty (26th January, 2022), dawidhubert (27th January, 2022), KADE007 (24th January, 2022), lion0304 (26th January, 2022), PremierD (9th February, 2022), s qubiak (24th January, 2022), Stelaras26 (24th January, 2022), Supas (24th January, 2022), taxo1965 (25th January, 2022), trinicolin (26th January, 2022), vas100 (25th January, 2022), weza247 (24th January, 2022)
Did you added any option to read opel bcm nec
hello guys
bmw x1 2010 frm 3 repair
-select the prtition size EEE to 0 Dflash 128
read Dflash then save
extract eep from D
write eep partition 16 sector and Dflash 0
open eeprom and write
when i write its ask me another time to select partition manually ... select yes but write error
any suggestion please ?
i repaired many frm by this way before
[2022-02-07 10:15:32] : Try Frequency success
[2022-02-07 10:15:32] : ID 2M25J 0XC482/3M25J 0XC482
[2022-02-07 10:15:32] : Start communication...
[2022-02-07 10:15:32] : D-FLASH: 65535 Sectors ( 16383.75 K ) EEE: 65535 Sectors ( 16383.75 K )
[2022-02-07 10:15:33] : User select yes
[2022-02-07 10:15:38] : Write length:0x1000
[2022-02-07 10:15:38] : PartitionD-FLASH: 0 Sectors ( 0 K ) EEE: 16 Sectors ( 4 K )
[2022-02-07 10:15:38] : Writting...(0%)
[2022-02-07 10:15:38] : Write Error
read
Actions speak louder than words
Did you try like this
http://blog.vvdishop.com/repair-bmw-...ith-vvdi-prog/
ttzag (7th February, 2022)
Yes i tried
Solved by write eep with last version of vvdi prog
Thank you
teerak2uk (7th February, 2022)
