Page 282 of 295 FirstFirst ... 182232272277278279280281282283284285286287292 ... LastLast
Results 4,216 to 4,230 of 4422
Thread: VVDI PROG
  1. #4216
    dd1's Avatar
    Aug 2014
    THANK YOU, I will try & report back.
  2. #4217
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by brend View Post
    Try this away...........
    MCU---->MOTOROLA-MPC660XXXX--->MPC5606B .
    Hello, i have looked and the mcu does not match with mine, mine has 80 pins and the suggested mcu has more pins, do not know how to proceed. thank you in advance
  3. #4218
    Jun 2022
    What cable do I need for VVDI
  4. #4219
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by Matt123456 View Post
    USB cable...
  5. #4220
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mates,
    Can anyone help me how to read this mcu please?
    D76F0117 on vag bcm
    Thanks a lot
  6. #4221
    Mar 2019
    Scandinavia
    I think you need to look under immobilizer section for audi/vw, if not look around. There should be connection for VAG BCM
    learning by doing, learning by experience... please thx is I helped you
  7. #4222
    peko's Avatar
    Jan 2010
    hi friends
    with new software update i can't change partiton to manualy
    how is possible change partition manualy in new updates ? to reading nfrm ? because not appear windows tu purpose it same as old version software
  8. #4223
    Hello !
    Tuareg 2013 BCM2 secured NEC MCU ver 0503 VVDI prog won't read DATA 2 also VVDI2 don't know this version!
    Is posibile add this BCM2 in VVDI prog and VVDI2 ?
    Regards,
  9. #4224
    Maartinj's Avatar
    Nov 2010
    Poland
    v5.3.0 (2023-08-30)
    >>>DOWNLOAD<<<
    * This version DON't need update firmware
    * Modify GL8 BCM(2017--)-WRITE, option in <4-IMMOBILIZER>-><BUICK>: Optimize the process
    +Add FENGSHEN S30(93C46A) option in <8-OTHER>-><Dongfeng>
  10. The Following 4 Users Say Thank You to Maartinj For This Useful Post:
    dawidhubert (15th September, 2023), rob h (9th September, 2023), rtbdiagnostic (1st September, 2023), teerak2uk (31st August, 2023)
  11. #4225
    Supas's Avatar
    Jun 2020
    Quote Originally Posted by Maartinj View Post
    v5.3.0 (2023-08-30)
    >>>DOWNLOAD<<<
    Martin, can you confirm that vvdiprog will not support reading RH850 micros? And that is why what was added in key tool plus was not added? and for that you will have to buy the new version of the equipment? Thank you
  12. #4226
    Jun 2020
    Shahtersk
    Hello, my vvdi-prog does not read FRM 3 mc9s12xeq384 3m25j frequency failed, it worked well. read write ok, and then stopped. I replaced the MC9S12 adapter but it does not read.
    crafter ezs 9s12xdt384 read ok, FRM2 9S12XDT256 read ok.
    how to solve a problem? or just the dealer?
    "sorry google translate"
  13. #4227
    rob h's Avatar
    May 2011
    When you say, then stopped. Could you read, and write. And now it does not connect anymore?
    So you have the ori frm data?
    Quote Originally Posted by Alexandr 119 View Post
    You could try the mcu menu.
    Motorolas, enjoy warmt, some warm them slightly.
    And sometimes, if it wont read, keep pressing read, until it reads.
    Frm, never gave me a problem. Perhaps a update before, it was better.
  14. #4228
    peko's Avatar
    Jan 2010
    Quote Originally Posted by rob h View Post
    i test both FRM with same problem "frequancy failed" and test menu to read MCU without success
    the way is use old version and fixe manualy frenquency
    i report this problem to support vvdi but nothing change and not give way ...
    if anybody have old version working, share it
  15. #4229
    brend's Avatar
    Oct 2015
    Same where
    Vvdi programmer has many disadvantages that are not solved .
    Because need have other programmer , when up this problem .
    NB!!! Don't ask in PM old file password , Im not remember.
  16. #4230
    fluorescent's Avatar
    Mar 2010
    ROMANIA
    i have my vvdi prog broken,the batery positive leg broken so now i have only red led light, the proggrammer is recognized by the pc but no yellow light blinking.
    i bought it from somebody year ago so i dont know where is boughted.
    can somebody provide a solution for this?
    is oem i have the serial .
    any more spam like what was in here and this account will be banned !!!
