Page 294 of 295 FirstFirst ... 194244284289290291292293294295 LastLast
Results 4,396 to 4,410 of 4422
Thread: VVDI PROG
  1. #4396
    peko's Avatar
    Jan 2010
    hi friends
    any succes to read SAK-C167CS ?
    SAK-C167CS-L33M
  2. #4397
    Apr 2010
    Hi.
    I need to clone A2139001722 with tricore TC277TP from Mercedes w205 control box, does anyone know how to do it, or which tool can I use successfully?
  3. #4398
    Apr 2014
    Spain
    Default SAM Mercedes A-Class W169 SAM module control unit A1695454332 5DK008728-16 PINOUT
    Here PinOut for read SAM Mercedes A-Class W169 SAM module control unit A1695454332 5DK008728-16
    MCU:ST10F269
    https://mega.nz/file/uM9F1L4Q#iuDAc_Pbca...RT07ZRSh0E
    EEPROM:95080
    https://mega.nz/file/bI0hFRQR#DvFq0NciB9...YpmGffyfuo
    I use VVDI Prog for MCU, and Orange5 for read EEPROM in circuite.
    I hope it will be useful for the forum users, and I hope Thanks and Reputations...
    Regards
    Don't forget to press the THANKS & REPUTATION button for help in the future.
  4. The Following 14 Users Say Thank You to danielif For This Useful Post:
    Andreastech81 (20th November, 2024), CLK1201 (20th November, 2024), dawidhubert (20th December, 2024), Diablotic (12th November, 2024), dijo (4th February, 2025), electromech (13th November, 2024), ilkapali (30th November, 2024), jodge (9th February, 2025), KADE007 (12th November, 2024), MOBILTRONIC (25th February, 2025), rob h (12th November, 2024), rtbdiagnostic (20th November, 2024), scotlock (17th November, 2024), triak88 (15th January, 2025)
  5. #4399
    Nov 2015
    Detroit
    Any body have pin out for RFH 2022 ram for iprog or upa s or orange ?
  6. #4400
    rob h's Avatar
    May 2011
    Post your partnumber, and picture from the print, front and back.
    There are 2 pcb versions rfhub
  7. #4401
    Feb 2016
    Malawi
    I have a problem with my VVDI prog - CAS3+ 0L15Y chip crack failure, I tried different MC9S12 cable, different CAS, soldering perfect and redone, and also changed power supplies, even though it has been working fine for the past few years with CAS3+ and many other modules but it seems this time it's likely given up.
  8. #4402
    honingkoning's Avatar
    Jun 2010
    Dessert
    Are u sure u use the 912 cable and not the other one,they look almost the same and the colors are the same
  9. #4403
    Feb 2016
    Malawi
    Quote Originally Posted by honingkoning View Post
    Hi yes, issue was in both the 9S12 cables - the wires (purple, yellow and green) were brittle so it was passing continuity test but couldn't be loaded, replaced with slightly thicker wires and now working okay.
  10. #4404
    Jan 2016
    where I can find this tool ?
  11. #4405
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by Master8 View Post
    ...............#4384
  12. #4406
    Jan 2016
    I was searching for hardware mate
    https://www.vvdishop.com/wholesale/x...60dw-chip.html
    this is a good price? does exist cheap version or only official one?
  13. #4407
    Jan 2016
    another question, I read at link above:
    "£ means the type will be supported in the future.
    ATMEL ATTINY £
    ATMEGEA £
    NEC uPD70F £
    ST TMS370 £
    MC9S12HY £
    MC9S12HA £
    MC9S12HZ £
    MC9S12XHZ £
    MC9S12B £
    MC9S12GC £
    MC9S12XS £
    MC9S12K £
    MC9S12Q £
    MC9S12C £
    MC9S12P £
    MC9HC(9)08 £"
    what tool I need to read/write NEC uPD70F ?
  14. #4408
    ricked's Avatar
    Apr 2016
    Europe
    there is no vvdi clone....
  15. #4409
    Sep 2011
    Brittany France
    Corsa D VVDI Prog Renesas V850 70F3379 frequency failed
    Hello. I'm just trying to read the Renesas V850 70F3379 MCU. The chip is in BCM corsa D. I have a "Try Frequency failed" error.
  16. #4410
    Jan 2024
    Does somebody tried to erase data from EEPROM B58253 24C02 with VVDI PROG. I connected WP pin 7 with pin 4 VSS Ground, but still cannot erase data. Read is possible.
