hello
No.
Only CPT, but i also need ISP and license.
I give ECU back to cliente.
hello
No.
For me it worked using connection in the picture I attached. Need to set voltage to 3.3V
Someone tested with NEC d70f3426? (Instrument cluster from passat)
musti418 (17th February, 2020)
Hello,
how can i read with VVDI PROG over the BDM function a ST "58BW016"?
i find only EEPROM&FLASH / ST / M58BW016 and this is over the Adapter, not over BDM.
soldering is good I checked pin by pin to make sure there was conecto y ever there was supposed to be and no connection where there wasn't supposed to be. i tried it with an mcu of the same family with mask id 0D69J it read it no problem. vvdi prog doesn't give me an option for the mcu I started above the 0D53J but they should be the same. could I have damaged the mcu by applying too much heat? what could be the issue. any help is appreciated thanks.
Sent from my SM-N950U using Tapatalk
Anyone managed to read 70F3469 WITH vvdi-prog?
esx503 (25th February, 2020)
Same here with 70F3426
paulis (25th February, 2020)
70F3426 vag are locked mcu
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
https://mega.nz/#!ERt1DCrK!EnIbrixDe...WATz9aNvRHiDOg
VVDI PROG latest software version V4.9.1 update
v4.9.1 (2020-02-19)
* This version DON't need update firmware
+ Add VVDI PROG USER MUNUAL 4.9.1version in Doc folder
+ Add ME17.3.0(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ABARTH>
+ Add MED17.1.10(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><AUDI>
+ Add EDC17CP54(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><AUDI>
+ Add EDC17C69(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ALFA-ROMEO>
+ Add MED17.3.3(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ALFA-ROMEO>
+ Add ME17.8.31(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ASTON-MARTIN>
+ Add MED17.7.5(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-> <ASTON-MARTIN>
+ Add MED17.7.7(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BENZ>
+ Add MED17.7.5(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BENZ>
+ Add ME17.8.3.3(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BENZ>
+ Add EDC17CP49(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BMW>
+ Add EDC17C76(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BMW>
+ Add MED17.1.12(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BUGATTI-VEYRON>
+ Add EDC17C79(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><CHRYSLER>
+ Add EDC17CP52(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><CITROEN>
+ Add ME1717.9.20(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><DACIA-LOGAN>
+ Add EDC17C70(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><FORD>
+ Add EDC17CP42(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><FORD>
+ Add EDC17C58(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><HONDA>
+ Add ME17.9.21(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><HYUMDAI>
+ Add EDC17C83(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ISUZU>
+ Add MED17.9.9(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><JAGUAR>
+ Add MED17.8.32(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><JAGUAR>
+ Add EDC17C79(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><JEEP>
+ Add ME17.9.21(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><KIA>
+ Add MED17.8.32(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><LANDROVER>
+ Add EDC17C79(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><MASERATI>
+ Add MED17.3.4(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><MASERATI>
+ Add ME17.8.3.3(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><MCLAREN>
+ Add MED17.1.27(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><VOLKSWAGEN>
+ Add ME17.5.24(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><SKODA>
+ Add ME17.5.26(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><SKODA>
habbyb (24th February, 2020), PocketHero (24th February, 2020), weza247 (4th March, 2020)
hello someone to read for volvo cem with renessa m30855fw
