Page 228 of 290 FirstFirst ... 128178218223224225226227228229230231232233238278 ... LastLast
Results 3,406 to 3,420 of 4348
Thread: VVDI PROG
  1. #3406
    Jan 2019
    Quote Originally Posted by hivrich View Post
    Go into the settings.
    Excluded Files and Location.
    Indicate the path to the newly unzipped VVDIProg4.8.9.exe
    To add a file.
    Save changes.
    thats unfortunatelly not answer, if is it virus or not.. if yes.. you just allow someone to put his/her trojan to your pc
  2. #3407
    Dec 2014
    Lithuania
    the file "NetClient.dll" and VVDI.exe -- packed "VMProtect packer" without a license, or roughly stolen.
    Therefore more or less authoritative Antivirus this file will be will remove..
  3. #3408
    Apr 2016
    Quote Originally Posted by duzi View Post
    no need even anti virus, on win10, system delete this file and you will not be able to start vvdi prog soft, story started on 4.88, now 4.89 same problem...
  4. #3409
    Feb 2018
    Quote Originally Posted by akidor View Post
    In VVDI Prog there is an option for MED17.5 (TP1766).
    Does anyone know if VVDI Prog reads MED17.5.5 as well? It also has a TP1766 inside.
    I tried it, but without success. With the right security bytes it will work I think, but who knows them?
  5. #3410
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi. I don’t understand why used this system vvdi. Please change it!!! It is a mess with antivirus
  6. #3411
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by alclot View Post
    Because in this life you get what you pay...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  7. The Following User Says Thank You to bearheroes For This Useful Post:
    alclot (24th January, 2020)
  8. #3412
    Newbie nsacodificadas's Avatar
    May 2019
    But from the first version that I detect the .dll as a virus .. what I did was to add the exception in the antivirus to a folder and then all the versions stuck there and never again a problem.
  9. #3413
    alclot's Avatar
    Sep 2009
    Melee Island
    Quote Originally Posted by bearheroes View Post
    That´s right hehe
  10. #3414
    ASCM's Avatar
    Oct 2018
    hello i have a problem with an bcm 2 audi a5 MCU 70f3239 reading ok but writing error
    tool does not erase mcu /i read in section MCU-RENESAS v850 70f3239
    any one can help me?
  11. #3415
    Apr 2019
    Hi all,
    is possible to read eeprom from Mercedes W164 ML 2012 year with vvdi prog?
  12. #3416
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by niksata90 View Post
    Hi all,
    There are a lot of Eeproms in a Mercedes ML 2012...
    Maybe a little more specific...
  13. #3417
    Apr 2019
    Quote Originally Posted by figani View Post
    Part number: 1649051500
    This are the photos: https://mega.nz/#F!ul0ihaAT!JzkroKP8zafpToTaPKBsig
    Thank you!
  14. #3418
    figani's Avatar
    Feb 2018
    Thank you!
    It's nec based Eis...
    As I know there is no bdm solution for this kind of mcu...
    Only by can bus...
    Vvdi bga for example...
    But only partial read/write...
  15. #3419
    Apr 2019
    Only by can bus...
    When i put the key in EIS 20-30 times the car start. The car made that with both original keys. I dissasembled the eis and i read it on bench with cables. After that i tried to read it with IR key but don't. The both keys work good (i checked the frequency and IR)
    I tried to collect the EIS data but when the tool asked to put the IR key i made that but not success. No reaction.
    Can someone help me how can i repair it?
  16. #3420
    Ukraine
    How to read and write MC68HC05X16 (0D62J) ?
