Page 234 of 290 FirstFirst ... 134184224229230231232233234235236237238239244284 ... LastLast
Results 3,496 to 3,510 of 4348
Thread: VVDI PROG
  1. #3496
    Mar 2017
    Hi there
    Now i see that is special thread about Vvdi prog...
    I have "misunderstandings" with immo box from old car...
    So mcu is Motorola 0j66d I am try to read with option immo box fiat immo box 0j66d but no successful...them I desolder and try direct like on vvdi blog how to read hc08 and still nothing (but did not solder 8mhz crystal)...
    Car is lancia Lybra 2003y and immo box is imm100.10.
    Is there solution or who did read this mcu or any help..
  2. #3497
    Fec001's Avatar
    Apr 2010
    Anyone did Jimny 2016 MB91F061 dash before? I can read dump but get write error at 0%
  3. #3498
    s qubiak's Avatar
    Jun 2017
    Polska
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
  4. The Following User Says Thank You to s qubiak For This Useful Post:
    PocketHero (29th May, 2020)
  5. #3499
    Jan 2010
    4.9.4 changelog?
  6. #3500
    s qubiak's Avatar
    Jun 2017
    Polska
    Quote Originally Posted by Diablotic View Post
    4.9.4 changelog?
    http://blog.vvdishop.com/vvdi-prog-v...r7f701330-mcu/
  7. The Following User Says Thank You to s qubiak For This Useful Post:
    Diablotic (27th May, 2020)
  8. #3501
    Mar 2017
    Quote Originally Posted by hitechservis View Post
    Hi there
    Just did it ...put mcu on adapter board...with 12mhz osc and read like 0j66d...
  9. The Following 3 Users Say Thank You to hitechservis For This Useful Post:
    daxxer (27th May, 2020), doctore (30th May, 2020), lock66 (21st June, 2021)
  10. #3502
    Maartinj's Avatar
    Nov 2010
    Poland
    VVDI PROG latest software version V4.9.4 update
    >>>DOWNLOAD<<<
    v4.9.4 (2020-05-26)
    * This version DON't need update firmware
    + Add VVDI PROG USER MUNUAL 4.9.4 version in Doc folder
    + Add R7F701330 option in <2-MCU-><RENESAS-RH850>
    + Add FENGJUN-7 option in <5-DASHBOARD-><GREATWALL>
    + Add TOYOTA-RAV4 option in <5-DASHBOARD-><TOYOTA>
    + Add BAOJUN-310/560 AIRBAG option in <7-AIRBAG-><SAICMOTOR>
    + Add T300 AIRBAG option in <7-AIRBAG-><ZOYTE>
    + Add NEW VISION AIRBAG option in <7-AIRBAG-><GEELY>
    + Add BAODIAN AIRBAG option in <7-AIRBAG-><JMC>
    + Add LYNKCO-AIRBAG option in <7-AIRBAG-><LYNKCO>
    + Add SRS-VW62 option in <7-AIRBAG-><VOLKSWAGEN>
    + Add AUDI-AC-CONTROLLER(R7F701548) option in <8-OTHERS-><AUDI>
    + Add FRM-E-SERIES-XDT256 option in <8-OTHERS-><BMW>
    + Add ESCORT-BCM option in <8-OTHERS-><FORD>
    + Add 8th-SONATA-AC-CONTROLLER option in <8-OTHERS-><HUNDAI>
    + Add SKODA-RADIO-STREAM option in <8-OTHERS-><VOLKSWAGEN>
  11. The Following User Says Thank You to Maartinj For This Useful Post:
  12. #3503
    Feb 2014
    Not much use in this new update - still missing some important Motorola MCUs.
  13. #3504
    ASCM's Avatar
    Oct 2018
    Hello why xhorse does not add cas4/cas4+ editor in menu why hexprog it have that?
    Sent from my SM-J415F using Tapatalk
  14. #3505
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by ASCM View Post
    why hexprog does not add 35160wt cloning with id in menu vvdi prog has that...?
  15. #3506
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by autoTkey View Post
    what type you mean ?
    many thanks to friend kevfield
  16. #3507
    Apr 2016
    uk
    Quote Originally Posted by figani View Post
    Why do you have to mention 35160wt when it can't read-write 24c04?
    Sent from my MI MAX 3 using Tapatalk
  17. #3508
    p1et's Avatar
    Oct 2013
    I have w211 HC12 EIS 211 545 10 08 (I guess 3K91D). VVDI Prog manual say use cable V3 but on picture with connection there is V1 cable (it tell to use V2 or modify V1).
    So which cable do I need to use? After I've seen that, I decided to first try with R260 blue clone but it keeps linking and can't communicate with MCU.
    I'm gonna try with VVDI but need be 100% sure which cable to use, in order to avoid (or minimalize) risk with that tricky 3k91d.
    I have xprog also which I used once in the pasgt with this mask and all good (auto verify OFF) but seen multiple opinions that xprog damage them also:
    UPDATE:
    OK I tried with V3 cable, communication OK, reading completed but file filled with zeros.
    So I tried my Xprog 5.0 clone and voila, read succesfull, keys generated and EIS is working with new keys
    UPDATE 2: Blue R260 clone also read this MCU no problem but with some software trick.
    Anyone succeed reading W211 HC12 EIS with VVDI Prog recently?
  18. #3509
    figani's Avatar
    Feb 2018
    Quote Originally Posted by comizelu View Post
    which device canīt read 24c04 write?
  19. #3510
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by p1et View Post
    UPDATE:
    I readed and writed this type of esz with ak 500
    Everytime perfect
  20. The Following User Says Thank You to ASCM For This Useful Post:
    p1et (1st June, 2020)
