Results 1 to 13 of 13
    Default Smart 450 p2010 problem
    Hi all , I got key symbole on. Dash and p2010 dtc in ecu, remote is open and close fine, no transponder inside. What should I do?
    I got avdi
    bearheroes's Avatar
    Dec 2011
    Lock and unlock or just blinking lights when you press buttons?
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    Quote Originally Posted by bearheroes View Post
    In the beginning yes but after syncing the key it is also open and close
    But still car doesn't start
    i_shot_the_sheriff's Avatar
    Nov 2008
    I also have this exact fault right now on a 450! IS it possible SAM is faulty?
    Quote Originally Posted by i_shot_the_sheriff View Post
    I wish I knew , this car is very uncommon here. I gave up on this one.
    Nov 2008
    I will try to read the flash from the 9S12 mcu inside the SAM and check it out.
    I will post all updates
  8. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
    totalkey (3rd June, 2015)
    Nov 2008
    Just to inform .
    Here's eprom and flash file from SAM unit . 2K79X mcu .
    Any chance someone has another flash to compare ?
    SAM 5WK45090.rar
  10. #9
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    i have it, take a look
    Press "THANKS" button. just one click, CHEERS
  11. #10
    Nov 2008
    Thanks for the share friend , yes i have this virgin file but i was wondering if FLASH is bad?
    Because problem i get is P2010 and it says about CAN communication between ECU and SAM . I've read on google it may be flash problem of SAM....
  12. #11
    Top Poster ekvas's Avatar
    Sep 2011
    eu
    Have you solved the problem with fault code P2010, I have same problem
  13. #12
    May 2015
    the Netherlands
    Got same issue here, update on solution?
  14. #13
    May 2015
    the Netherlands
    update, got the remote programmed into SAM module, central door locking started to work again.
    but still no start and on display shows the key failure.
    after battery change error was gone and car starts again.
