Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Jun 2010
    Default p206 cc after immo off dont work the a/c
    hello to all.i have a p206 in my garage.the client bought it before one month and brought to me because the aircondition didnt work.after a search i found that the problem was from the ecu that was immo off...if i will actuate the a/c clutch from the bsi with diagnostic the clutch works..to the engine ecu parameters i see that the a/c commnd is off..the ecu is me 7.4.4 0261207477
    is there any immo off file with a/c command on?
    what else can i do?
    Dec 2009
    That dump many people include me are looking for too.
    Just thought to emulate such signal from ECU sent to BSI, possibily on one wire and and just the logic hi/lo, not tested.
  3. The Following User Says Thank You to Zmann For This Useful Post:
    d.zio (4th June, 2015)
    roman_auto's Avatar
    Aug 2009
    Check coniguration in the ecu, you wipe out to many areas
    If It Helped Push Thanks
  5. The Following User Says Thank You to roman_auto For This Useful Post:
  6. #4
    Dec 2009
    Quote Originally Posted by roman_auto View Post
    Tried, config is not a concern. Some CAN data was interrupted, check vehicle speed in ECU para_Driving then will see.
  7. The Following User Says Thank You to Zmann For This Useful Post:
  8. #5
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Def configuration................use pp2000 to tell ecu it has a/c ................ immo off dump was probably a dump from another car and didn't have a/c..............had this problem before on several pugs.
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
  9. The Following User Says Thank You to darrenhyland For This Useful Post:
  10. #6
    Dec 2009
    Good to look at this
  11. The Following User Says Thank You to Zmann For This Useful Post:
  12. #7
    Jun 2010
    i checked and other two immo off solutions but no ac again.....i did and config with planet ang again nothing.
    i left the flash with immo off and did the eeprom virgin and configurated with planet and again nothing
    i saw that the bsi is and this changed but i think this is not a problem
  13. #8
    Top Poster youk's Avatar
    Nov 2009
    france
    hi, send me your ori file
  14. #9
    Jun 2016
    Greece
    Did you find the solution? I have the same problem...
  15. #10
    Mar 2016
    hello to all ...the file immo of flash 29 f.... and eeprom... ecu 7.4.4 we have a problem not worgin clima after immo of file.. I upgraded software but nothing [oringinal servise] the proplem is the file some gate [ffff or adff] kept closed tomorow i post some file ..i have same ecu 7.4,4 immo of but clima not worgin ,,,,,,,,not its the problem simple air or clima
    many efforts serviceable nothing some idea
  16. #11
    gkogkolos's Avatar
    Oct 2015
    Athens, Greece
    Default 0261207477 IMMO OFF
    Start your engine bro..or anyone else who need it ;-)
    No need to cut any pin or something, no problems with the fans, temp, etc.
    Just flash the files and voila. It will never lock again, immo off total.
    Press Reputation +1 = Password in PM
    regards
  17. The Following 14 Users Say Thank You to gkogkolos For This Useful Post:
    adnanerkardes (21st July, 2018), bartas666 (12th April, 2018), d.zio (25th March, 2020), digital320 (11th July, 2017), ferchu2323 (13th June, 2018), kaliska5 (21st July, 2023), mahrouf (6th July, 2017), Mario32 (24th October, 2020), schouten1977 (21st February, 2018), shtyrya2 (27th December, 2018), tawfeg (24th April, 2019), xjojo (31st March, 2018), zeljko84 (28th September, 2017)
  18. #12
    Jul 2010
    can i have pass please rep sent
  19. #13
    Jul 2010
    pass please :-)
    Quote Originally Posted by gkogkolos View Post
    regards
  20. #14
    May 2011
    passs plz
    regards
    [/QUOTE]
  21. #15
    ElectroRadar's Avatar
    Mar 2018
    Mexico
    Someone who pass me the password please Gkogkolos does not answer
