Results 1 to 15 of 15
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Connection SID803 BDM Help
    Hi mates, i trying to read ECU Siemens SID803 by BDM, i consfused bcause y found in forum differents pinouts for this ecu.
    I try to connect DSDI, DSDO, DSCK, PORST AND GND and power supply to ECU connector.
    I use two tools, x-prog V5.51 and FGTECH V53. With x-prog nothing happed, the bar still quiet, i never use this tool to read MPC, and with FGTECH at first moment appear error log message.
    For read with x-prog is necessary connect VFLS1 and VFLS0? is necessary use adapter 9s12-BMD? i need change HZ value?
    I am ussing this connection.
  2. The Following 2 Users Say Thank You to ruffles1986 For This Useful Post:
    capi (4th June, 2015), valery72550 (29th October, 2018)
  3. #2
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default connections
    this is good connections
    regards
  4. The Following 12 Users Say Thank You to vasko For This Useful Post:
    ayllon308 (13th February, 2021), brane0001 (23rd July, 2020), dvdpgn (15th September, 2016), Eddie034 (17th March, 2020), Elektrik001 (18th September, 2019), elitricista (23rd February, 2016), ilkovelichkov (11th June, 2020), martinracing (30th March, 2018), ombre57 (3rd June, 2022), ruffles1986 (4th June, 2015), stanislav georgiev (2nd March, 2017), Szokimoki (23rd May, 2020)
  5. #3
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    read by bdm
  6. #4
    Sep 2011
    In the Garage
    I have fgtech v53 and xprog... any experience with it?
    Sep 2011
    In the Garage
    Quote Originally Posted by vasko View Post
    regards
    I use same connction but not luck for me, with fgtech i had error when try to conect, and with xprog the bar still quit and not advanced, appear not connect also.
  8. #6
    carefull BDM 100 and fgtech bdm pinouts are inverted. its not the same. taht is why fgtech uses a intermediate adapter...to convert from fgtech pinout to normal BDM
    u have ktag?
  9. #7
    Sep 2011
    In the Garage
    I not have ktag. I ditectly conect wires from fgtech to ecu, but i check fgtech pinout. For xprog maybe is necessary comect vfsl0 and vfsl1?
  10. #8
    morfej's Avatar
    For galleto I make it like that.
  11. The Following 12 Users Say Thank You to morfej For This Useful Post:
    dvdpgn (15th September, 2016), Elektrik001 (18th September, 2019), galiza (27th December, 2018), hollow (28th February, 2016), Jashmine1983 (25th October, 2016), mexanico1971 (22nd July, 2017), MOBILTRONIC (16th February, 2017), ruffles1986 (5th June, 2015), SALAS (21st November, 2017), stormb (1st May, 2024), Szokimoki (23rd May, 2020), theislandhub (10th June, 2019)
  12. #9
    Sep 2011
    In the Garage
    The problem with my tools was i need connect vfsl0 and vfsl1, i test them with siemens ppd 1.2
  13. #10
    Jun 2011
    Northamptonshire, UK
    I have just found this thread and was going to day I have used xprog for this ecu and it worked well and was thought it was because you didn't have the other two connections connected. Glad to see you found the fault
    Sent from my Hudl HT7S3 using Tapatalk
  14. #11
    Dec 2016
    Hi guys. I'm new in reading and writting tools and I can't seem to succeed in BDM Reading with both galletto and K-tag, all connections are OK. I wonder if my bdm adapter is faulty? Also I don't understand about vfsl0 and vfsl1, do I need to short them ?
  15. #12
    Jan 2017
    N/A
    Thanks to morfej finally i read this ECU in BDM with GALLETTO v54.
    I use BDM/JTAG MPC55x/56x driver.
    I tried with BDM Siemens OptiCan 201 adapter clone and other diagrams from the web but nothing works.
    Diagram from morfej works 100%.
    Big thanks.
  16. The Following User Says Thank You to SALAS For This Useful Post:
  17. #13
    Sep 2016
    Quote Originally Posted by morfej View Post
    Will this pinout work with V54 and Simos PPD1.3?
  18. #14
    Sep 2016
    I can confirm this pinout does indeed work with V54 and PPD1.3
    Thanks again Morfej
  19. #15
    Sep 2016
    I have edited the picture from Morfej to show the colour coding of the open ended wire supplied with most Galletto and added some instructions on safely powering the device and ECU
