Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 83
  1. #31
    Oct 2013
    Garage
    Hello, maybe someone have ktag fw with activate tractor protocol ? Can be older ex V5.001, thanks for any advice
  2. #32
    heteromies
    Guest
    Quote Originally Posted by majsterx View Post
    6.070 is all open...
  3. #33
    mbtun's Avatar
    May 2012
    Europe
    Please read above ... for NO PASSWORD files.
    Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
    Bapro 4x4 dyno + SP6
    Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
  4. #34
    Sep 2015
    halo
    Why can not I download files on my computer
    user name correctly
    pasword is okay
  5. #35
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    user name correctly
    pasword is okay
    what ??
    Firstly you even don't introduced yourself
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  6. The Following User Says Thank You to CustomCars For This Useful Post:
    teamtuner (10th November, 2015)
  7. #36
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by lamnan View Post
    halo
    user name correctly
    pasword is okay
    First step is to go here and do an intro
    http://www.digital-kaos.co.uk/forums...oduce-Yourself
    and while you're waiting for the site to update, go here and read:
    http://www.digital-kaos.co.uk/forums.../2-Forum-Rules
  8. The Following User Says Thank You to clusters For This Useful Post:
    CustomCars (15th September, 2015)
  9. #37
    Apr 2012
    Wonderland
    nxp file posted it's 5.001....not 6.070
    flashed 3 times on a new nxp, so no crp3, so no 6.070
  10. #38
    prusony's Avatar
    Belarus
    Quote Originally Posted by yourmate View Post
    Honestly, this is the last time I try to spark some light in these heads - I do promise
    So guys you can find the KTAG 6.070 upgrade kit WITHOUT ANY PASSWORDS HERE (#101), HERE (#20) or in fact HERE (#21)
    Of course you need to be able to read for this.
    Alternatively you can litter the tread with your miserable "password please" messages.
    #unsubscribed
    HI! Who will say for sure 100% - NXP-proc closes J-TAG port after THIS update ??? Or not ???
    TNX, Alex.
    Non ut edam vivo, sed ut vivam edo.
  11. #39
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by prusony View Post
    TNX, Alex.
    5.001 not close comunication with j-link
    6.070 close comunication nxp.....unlock only with tokens
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  12. The Following User Says Thank You to teamtuner For This Useful Post:
    prusony (10th November, 2015)
  13. #40
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    HELLO FREND YOU HAVE ANY SOLUTION TO UNLOCK WHIT JLINK AFTER UPDAT 6.070
  14. The Following User Says Thank You to rabie_m For This Useful Post:
    diagauto741 (25th December, 2017)
  15. #41
    cp2010's Avatar
    Feb 2011
    DE
    solution is only one, change mcu to new one
    KESS 5.028/5.030 VR - KTAG 8.000 EU PCB
    PCMFlash 1.2.0 dongle EU
    STool/MTool v1.49 EU
    ECU Flasher activation
  16. #42
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by rabie_m View Post
    why you need to unlock?...youhave another firmware to reflash? superior firmware wersion? why you don"t use tokens reset?(or something similar)
    outside forum:
  17. The Following User Says Thank You to teamtuner For This Useful Post:
    moky (10th November, 2015)
  18. #43
    moky's Avatar
    Behind you
    teamtuner
    have you got please sd card files from 6.070,i have customer client code problem on tras and ktag..
    thanks!
  19. #44
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by moky View Post
    teamtuner
    thanks!
    there is not any visible content of sdcard from 6.070...all content is sistem file format invisible...your sdcard,if try to read,will tell thatneed to be formated
    i use rawcopy to write sdcard with .bin file content sistem files from 5.001,and after that i remade the update
    if your tool said that need to conect on iternet for update,change anly the sdcard wit anotherone new sdcard 2Gb,and only start again update
    outside forum:
  20. The Following User Says Thank You to teamtuner For This Useful Post:
    moky (11th November, 2015)
  21. #45
    moky's Avatar
    Behind you
    ok thanks but I don't arrive to update sd card,i have customer and group code clear..
    firmware is 6.065...if you can help
    please send me file from 5.001 !
    many thanks
