Results 1 to 13 of 13
    super jumbe's Avatar
    Livingstone
    Default NEED SOFTWARE OP-COM 150406b.
    Lads, can some 1 help me with none internet updating op-com 150406b software, tried one on google and is asking for email and pass. Need a Chinese one.
    Thanks in advance.
  2. The Following User Says Thank You to super jumbe For This Useful Post:
    ramzyharb (25th June, 2020)
  3. #2
    Dec 2012
    Quote Originally Posted by super jumbe View Post
    Thanks in advance.
    Where did you get the tool from if yours has yellow stickers with serial numbers on it need to contact supplier of your tool
    The version i have does not work with ?10 hardware
  4. The Following User Says Thank You to gazvts For This Useful Post:
    super jumbe (9th June, 2015)
  5. #3
    Livingstone
    Quote Originally Posted by gazvts View Post
    No it looks like this interface, it will not connect with 2014 corsa, which software will be possible?
    Thanks in advance.
  6. #4
    drakov's Avatar
    Aug 2008
    to use latest software you will need a specific clone interface and if I remember the software itself will need to be unlocked
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  7. The Following 2 Users Say Thank You to drakov For This Useful Post:
    gazvts (9th June, 2015), super jumbe (9th June, 2015)
  8. #5
    Livingstone
    The interface I have works up to Corsa D 2010 and Astra H, but will not read corsa 2013-14, thanks lads a better start goggling for a very latest interface and software.
    Thanks appreciate your time.
  9. The Following User Says Thank You to super jumbe For This Useful Post:
  10. #6
    gopelhu's Avatar
    EU
    Hi all,
    Here is the working solution any china clone op-com.
    Regards, G
  11. The Following 4 Users Say Thank You to gopelhu For This Useful Post:
    Blood58870 (2nd March, 2020), tourettes (27th March, 2018), uldis89 (18th September, 2015), wazspaz (19th August, 2019)
  12. #7
    gopelhu's Avatar
    EU
    Thanks in advance.
    Hi M8,
    If you need this old version pls write me pm.
    Regards, G
  13. #8
    Jul 2016
    i am also needing this software so i hape it will work
  14. #9
    Aug 2008
    this software is for hq clones only
    the clones sold from china are only using the software in post 6 and some other software thats a mix
    120309a and no higher
  15. #10
    Jun 2018
    Quote Originally Posted by gopelhu View Post
    Hi all,
    Regards, G
    Thank you so much
  16. #11
    Which op com is best to program key to a astra j 2013 reg. Thanks
  17. #12
    Aug 2019
    Hi all,
    Regards, G
    Thank you for uploading this. i will try later.
  18. #13
    Mar 2017
    did you get this software if you get it please send it or share for others
