Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 101
    Dec 2010
    Default Johnson Control BSI flash
    I have a BSI from peugeot partner, after ren pin code with a chinese tool flash was kill. Want to recover write new flash but I can identify what processor use this BSI, please in attach picture from BSI.
    ORIGINAL.rar
    Also I read eeprom somebody can give pin code please?
  2. The Following 2 Users Say Thank You to jacostanzo For This Useful Post:
    Kfouka (2nd March, 2021), reks13 (3rd July, 2016)
  3. #2
    Siham's Avatar
    Jul 2014
    Did it with FVDI ? FVDI fly or clone ?
    If its the case , connect battery charger an you car battery and retry the procedure ,flash is not corrupted its the BSI that is in boot mode.
    Tried on 2 peugeot 308 with BSI jonhson and it worked but tooked 50 min .
    No thank , no HELP .
  4. The Following 4 Users Say Thank You to Siham For This Useful Post:
    Col19 (11th December, 2020), jacostanzo (12th June, 2015), key4man (29th July, 2020), lion0304 (21st August, 2015)
  5. #3
    Moderator
    PremierD's Avatar
    Jun 2009
    If you require it the Pin is 76GB mate
  6. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    Col19 (11th December, 2020), helmi reguig (11th June, 2015), jacostanzo (12th June, 2015), tomasKaos (18th December, 2021)
  7. #4
    helmi reguig's Avatar
    May 2011
    altamura bari it
    ________________________
    Thank you
    http://www.digital-kaos.co.uk/forums...311316/:party:
  8. The Following 2 Users Say Thank You to helmi reguig For This Useful Post:
  9. #5
    Moderator
    PremierD's Avatar
    Jun 2009
    AVDI to read a pin mate ... .. a bit of overkill don't you think .
  10. The Following 15 Users Say Thank You to PremierD For This Useful Post:
    angelx431 (20th June, 2019), bearheroes (11th June, 2015), brodaty (11th November, 2019), BusCan (30th November, 2022), Cesarec (8th July, 2016), Col19 (14th January, 2021), Hayssam1 (11th April, 2025), helmi reguig (11th June, 2015), iamfooser (11th June, 2015), jacostanzo (12th June, 2015), Johnner (19th June, 2015), lidons (18th June, 2016), mnem (30th November, 2020), tomasKaos (16th December, 2021)
  11. #6
    Dec 2010
    Quote Originally Posted by Siham View Post
    Was with FVDI, i will try this procedure. Thanks
  12. #7
    DashProg's Avatar
    Jan 2013
    Here
    Send your bsi ref please
  13. #8
    Hungary
    I've the same problem. I did the procedure, but it has not changed. Can anyone help?
    Kari
  14. #9
    Nov 2015
    Hello!!! Does anyone have a solution for this problem??? I just killed a JCI BSI on a 2011 partner, nothing works, I have 14,25 V on the supply tried to write km, or read pin, nothing brings it back to life, I can read the flash with the ecu flasher option on FVDI, but when trying to write it back I get checksum error. Please help!!
  15. #10
    Nov 2015
    Sorry is there any way to calculate the checksum of the file that I allready have and try to reflash it??? Or is there any chance to get another file?? BSI JCI 9666895580 Thank you!!!
  16. #11
    Macedonia
    Find your backup file.FVDI makes backup,then write it with SMOK psa tool or original AVDI.I had problem with Picaso stuck in boot mode .Smok tool solved in 20 min 100%.It is flash file.
  17. #12
    Nov 2015
    Sorry m8, but if I had the SMOK or the original AVDI I wouldn't find myself in this situation in trhe first place, don't you think? I've allready tryed to reflash the backup that FVDI made in the documents folder, but no joy because it had the "checksum error". In the end I managed to find a collection of berlingo flash dumps, chose the right one and flashed it with the same FVDI that killed the BSI in the first place, trough the "ECU Flasher" option and padabum, everything came back from the deads. I will upload the dumps for other helpless souls, with special thank's to Alexander74 that posted it in the first time. Hope this will be helpfull to anyone!!!
  18. The Following 48 Users Say Thank You to stefyhgs For This Useful Post:
    AMZDia (27th April, 2022), ancient (13th November, 2017), Axelis (16th October, 2022), ayet (19th April, 2018), brodaty (11th November, 2019), Cesarec (8th July, 2016), Col19 (11th December, 2020), Dalautos (6th February, 2019), dinar (6th June, 2017), djimer (11th June, 2017), Domingo1111 (13th January, 2021), eltasol (29th November, 2022), gogoli (21st July, 2022), gzaor (25th April, 2019), Hayssam1 (26th May, 2022), ireks (1st July, 2024), javier1223 (17th January, 2023), juanes 3 (20th June, 2021), jupulino (23rd June, 2023), key mechanic (16th September, 2022), koska75 (10th March, 2017), kronk92 (10th February, 2019), lidons (22nd June, 2016), lordraidem (4th August, 2021), lounadak (5th December, 2020), lucaslacerda (6th June, 2019), madbg (17th October, 2018), MarekP (12th March, 2023), mariantv (12th February, 2017), megavolltt (3rd February, 2021), mkii (31st December, 2020), mnem (1st November, 2020), Nicolas9 (5th November, 2017), Oktawian (18th July, 2022), radoslawwiklik (10th October, 2018), Raffy haddad (7th October, 2016), sensey (15th April, 2024), sido1988 (28th November, 2020), skellykeyz (9th July, 2020), stefan11 (22nd September, 2017), surdeanuliviu (12th March, 2018), talazso (27th September, 2024), Talleresmalaga (1st July, 2018), tirnanic malisa (13th September, 2023), tomasKaos (16th December, 2021), triak88 (21st June, 2016), xipsilon (29th September, 2021), zas010970 (23rd October, 2023)
  19. #13
    What version psa fvdi did you used for reflash?
  20. #14
    Nov 2015
    Sorry for the late reply. I used version 6.3 of the FVDI PSA Commander. Regards!!!
  21. The Following User Says Thank You to stefyhgs For This Useful Post:
  22. #15
    Quote Originally Posted by stefyhgs View Post
    THANK YOU VERY MUCH
    YOU SAVED MY DAY
