Results 1 to 15 of 21
    Mar 2015
    Default How to read sirius 32
    Hallo guys
    I would like to read a sirius 32 from a 2000 clio 1.4 for immo issues itryed with galletto 1260 but some how i doesnt read i think because the immo is on tyed in another clio it reads no problem. ihave fvdi en xprog if someone can help with how to read on bench it wil be very nice
    thank to all
    DashProg's Avatar
    Jan 2013
    Here
    You just desolder the 29f and you read it on the bench
    stefaudio's Avatar
    BULGARIA
    Yes open ECU and read AM29F200BB with programmer(Willem,TL866)
    Mar 2015
    ok thnx en with fvdi i dont have willem i only have xprog en fvdi
    bangreno's Avatar
    Oct 2011
    TL866 is verry stable for this chip , with adapter
    Shmortz's Avatar
    in the middle of nowhere
    willem is also very good old programmer, I use one from 10 years, it is very good for many eprom and flash used in many ECU's and it's very cheap...
    Mar 2015
    ok thnx do u khnow where i can order one ?
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    read it with galletto on boot mode flash
    bR
  9. The Following User Says Thank You to pandokrator For This Useful Post:
    martinracing (28th June, 2015)
  10. #9
    Mar 2015
    Quote Originally Posted by pandokrator View Post
    bR
    thanx i have only galletto 1260 is it possible with this one i can read it on the car but i have only 64kb flash memory
  11. #10
    Mar 2015
    En do you have de pinouts from the OBD cable galletto 1260 to ecu ? like from the obd pins to ecu .
    Thnx a lot
  12. #11
    Oct 2008
    Eu.Gr
    pin of ecu is the same for any obd connector,
    use any obd cable with wires connected to ecu pin or just a simply wires
    for connect your 1260 use :
    pin 7 galletto ---- pin 56 ecu
    pin 16 galletto ---- pin 29 & 30 ecu == +12V
    pin 4 & 5 galletto ---- pin 3 ecu == GND
    pin 28 on Flash ground it with one resistor 1K --- give power to ecu --- remove GND from resistor ---
    read data with 1260 --- ;-)
    same procedure for read - writing
    bR
  13. #12
    Apr 2013
    you can use willem
  14. #13
    Mar 2015
    bR
    thnx for thr info
  15. #14
    Mar 2015
    thanx to all of corse
  16. #15
    paris
    programmer more best
