I'm not 100% sure, but i think it must be ok. This file is yours tuned, with FAP off and P1421 disabled.
Please test and report...
Regards!
Guys, I have here P307 2.0HDI RHS engine with removed DPF, here is ECU Flash dump from car, DPF removed and tuned but with error P1421, downstream temp sensor, which is burned. I found original dump for this car and put 1,3kOm resistor to see about 100 C temperature on cat and there is no problem, when I put soft from car or other soft with DPF off I have permanent fault P1421.
Somebody to help to remove this error from ECU please!
Regards!
thanks, I will try today and report!
problem solved, thank you!
I have the same problem. For any number computer is this file?
0281011081103736
1037364193B075WF
Yes, this is my file, I need a password for the archive, please help!
This file will probably work on my car.
What is your password, please?
Hello, I have a Peugeot 307 2.0HDI 107cv, ECU number: 0281011081 1037364193. DPF is removed -
software and hardware. Please someone can remap and tuned within the limit value. This is my ecu file with DPF OFF:
Peugeot_DPF Off.rar
Is it possible remove error P1421 from this ECU?
307_281011081-1037364193.zip
hello i have the same probleme can you help me plz ?
this ori file in attached piece.
thank u
This error comes up when you FAP off this car with ECUsafe
ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
