i have made the DPF off with ECU safe 2.0.0.0, so the car blocked at 3000 rpm and the DTC is permanently not fugitive, with millage ON ...
You need desactivate aditive ecu in bsi
I need DPF off and P1421 removed too
Thank you all,
pezho 307 original.rar
Try this and report.Pass on PM
ditjon0000 (8th January, 2016)
the error is still on, any other help please
Your file FAP OFF with P1421 OFF
BR
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
And the pass is!!
Files for 307 2.0HDI (RHS) 79KW?
hello i've the same probleme with p1421 no trouble but i want to kill him can you help me please ?
this fapoff file and ori 364193 in attached piece.
thank you
No problem i found the solution.
Found this with winols in 16bits and ff and lohi : 1421 00D0 00D1 00D2 00D3 00D4 00D5 00D6 00D7 0FFB E4D6 1114 0F10 E4D7 0001 C305 and modify like that 1421 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF and the dtc p1421 is off
aroo84 (7th July, 2017), BrunoXme (5th September, 2016), furnata (10th January, 2017), galiza (25th January, 2019), icogsm (19th February, 2016), karol450 (30th May, 2016), majster10 (18th March, 2020), pipina (30th October, 2017), Tawe (29th November, 2016), TeiS (7th September, 2016), zziad (17th March, 2016)
please pass for this file! thanks!
Jakie jest hasło, proszę
hello i have a same probleme can you help me please
