all sky movies have moved frequency scanned the box and got them back
Hi , this is my first post after reading and learning a lot from all the useful info on here . I've managed to fix /update every issue I've had myself after a bit research on here up to now but this one has me stumped . I have a skybox F5s and have performed a full " blind scan " and its just the same . What am i doing wrong ? any help greatly appreciated -
Sky Showcase is on a different TP to all the other Sky movie channels, so hasn't been affected...yet.
All the other Sky movie channels have moved from 11836H to 11934V.
You just need to do a single TP scan on 11934V to get them back. They will be listed at the end of your "all channels" list. The original non-working channels will not be overwritten by the new ones.Comment
any chance u can tell me where to look for that setting on openbox v8s m8..i found tps list with all fequencies in but can see how you would do a single..thnxComment
Hi If you have done a blind scan and channels not found it could mean your dish may not be aligned correctly. Before doing a blind scan i suggest you delete all TP's and then redo the blind scan. If all channels not found then you have a alignment issue or box may be faulty. What is your signal quality/level???Hi , this is my first post after reading and learning a lot from all the useful info on here . I've managed to fix /update every issue I've had myself after a bit research on here up to now but this one has me stumped . I have a skybox F5s and have performed a full " blind scan " and its just the same . What am i doing wrong ? any help greatly appreciated
RegardsComment
Here guys if anyone wants it /or are too lazy to do it yourself, see the attached link - iv just re-scanned the channels and added them back into the favorites list and deleted the old ones.....
Well after re-reading Hadrons advice I realised I had scanned them properly , they were just on "all" as opposed to favourites . My attempts to move them to my favourites were succesful but a bit jumbled so thanks dpool for that link i will load the new list after tea and report back .Comment
downloaded and now sorted thanksHere guys if anyone wants it /or are too lazy to do it yourself, see the attached link - iv just re-scanned the channels and added them back into the favorites list and deleted the old ones.....
https://www.dropbox.com/s/we5wl3udmc..._PROG.dbs?dl=0Comment
thanks for that , worked a treat ....
Your a life saver i was going to do this my self. thanks alot!Here guys if anyone wants it /or are too lazy to do it yourself, see the attached link - iv just re-scanned the channels and added them back into the favorites list and deleted the old ones.....
