Results 1 to 13 of 13
    drpeter's Avatar
    The Netherlands
    Default Passat 2011 color display engine error km same
    My customer has a problem, i did the km's (only 7000km lower). The car has a engine problem (also before). I cleared the errors with vcds. The customer drives a while and the engine code come back with the original km's!!! I tried to clear also with abritus, same problem. I searched for errors a level lower, nothing found. What can it be? I recoded the engine same problem???? Suggestions? Thanks
    What engine size is it? If it's 1.6 diesel
    Then the km are stored In the siemens pcr2.1 ecu.
  3. The Following User Says Thank You to javyb For This Useful Post:
    PremierD (17th June, 2015)
    drpeter's Avatar
    The Netherlands
    Yes it is 1.6.
    May 2014
    Belgium
    in ecu not active km, cant come back
    iProg-carradio
    Guest
    please send number dashboard 3AA 920 xxx or 3C0 920 xxx or 3C8 920 xxx ????
    Quote Originally Posted by zmeiarm View Post
    Yes it is active in 1.6 siemens ecu only way is to correct km in ecu
    drpeter's Avatar
    The Netherlands
    Customer is gone now when he call i will read the dash no. To be clear the km on the dash don't come back only the error engine code with the original km behind it. The car has a real engine problem.
    May 2011
    nec24c64 uds tft color
  10. #9
    Oct 2014
    Netherlands
    It seems VCDS can read the mileage also from older engine ecu's.
    So it seems normal that this engine ecu mileage is reported, instead of the mileage from cluster.
    (With newer ecu's like EDC17 the mileage cannot be read, so only cluster mileage is reported ..)
    Rgs H2Deetoo
  11. #10
    Mar 2013
    Disconnect any sensor on any of these and you will always get genuine km back ,same as bms ,mileage correction is becoming an illusion .
  12. #11
    Jun 2009
    CZ
    no problem to change km inside pcr 2.1 Wok
  13. #12
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by wokounek View Post
    Explain us how what string and how to calculate.
    Checked several files not able to see km.
    Wbr
  14. #13
    Jun 2009
    CZ
    send pcr2.1 eprom bckup Wok.
