here
DTC_1457_CHCK_OK.rar
here
jjas40 (24th June, 2015)
good job
worked
paskizo (27th November, 2017)
Hi friend.
4007 hdi 2.2 edc16cp39
i try but errors and mil light on.
p1161
p1351
p0487
many thanks in advance.
how do you do that fap off file? with volta or ecusafe? it is crappy!!
try this file, it is completly different.
test and report.
Ivanrojo It seems to work, the MIL does not turn on, I'll wait a while because the other times it seemed to work and then it appeared. A single throttle valve error appears, p2100. Thank you very much for your help.
It seems to work, the MIL does not turn on, I'll wait a while because the other times it seemed to work and then it appeared. A single throttle valve error appears, p2100. Thank you very much for your help.It seems to work, the MIL does not turn on, I'll wait a while because the other times it seemed to work and then it appeared. A single throttle valve error appears, p2100. Thank you very much for your help.It seems to work, the MIL does not turn on, I'll wait a while because the other times it seemed to work and then it appeared. A single throttle valve error appears, p2100. Thank you very much for your help.It seems to work, the MIL does not turn on, I'll wait a while because the other times it seemed to work and then it appeared. A single throttle valve error appears, p2100. Thank you very much for your help.
you are welcome hope it work ok for all time.
