    khalilo_de's Avatar
    Default help on A-class w168 170 CDI IMMO
    hi everybody,
    i need help with w168 IMMO problem star error in instrument
    the original transponder is unknown when i read car with mb star in acttual value the transponder not recognized
    i bought 2 hand immo box and i made transponder with gambit now the transponder is recognized but still get transponder invalid
    and i cant make coding in ecu identification carried out ( ecu virgin ) so pleas could some one generate a good transponder for mee
    immo file in attIMMO HC05 0D69J.rar
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Use emulator ... all OK
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    Minsk, Belarus
    Hi! This key is for this damp. But If old IMMO dont read key (hardware fault) may be You need copy data from old IMMO to new IMMO and dont need learning ECU and dont need generation new key. If key wrong You need only generation new key (without learning ECU). If need, pls write more about your problem
    BR
    khalilo_de's Avatar
    Quote Originally Posted by adikk View Post
    BR
    Hi addik your keys are not working
    khalilo_de's Avatar
    Problem solved i made key with gambit and car start
    Minsk, Belarus
    You need close (config) chip before using as in .txt files, but if problem solved - its not important. BR
  7. The Following User Says Thank You to adikk For This Useful Post:
    vanos batam (23rd June, 2015)
