Results 1 to 4 of 4
    soxten's Avatar
    Mar 2013
    Default SsangYoung auto.gearbox controll unit. Need help
    I have a new controll unit for automatic gearbox as coustomer has try to program in to car but some how get faults after programming.
    Now canbus not working correct and it don't shift gear.
    I have a used controll unit from a working car as i have read out flash 29F400 and program in to the new unit but it still don't work...
    I think that the NEW SsangYoung unit has fault in MCU infineon SAK-XC167CI -32F40F BB
    I think that mcu handels how everything should work on the controll unit and flash is holding car config information.
    Have someone hade this problem before?
    How to read this Infineon mcu?
    36600-32000 / 366003200
    0578-640122 / 0578640122
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Yellow and blue sticker units are not compatible...
    If original is yellow,then need yellow unit then.
    soxten's Avatar
    Mar 2013
    Correct! Both are blue.
    Do you know more about this type of units?
    Newmotors's Avatar
    May 2019
    brazil
    friend i have the same problem manged to solved?
