Results 1 to 12 of 12
Hybrid View
    Sep 2013
    garage
    Post Renault Scenic strange fault
    I have this Renault scenic from 2005 1.6 engine that is acting strange (some time not all the time ) is not starting , dash si not working , fan is runing , ...no communication on diagnostic (OBD) at this point can network is down , all fuses are ok , upc module is ok , uch ok(in my opinion) .....any ideas ? ... THANX
  2. The Following User Says Thank You to Mr BLACK For This Useful Post:
    DomnulNegru (5th May, 2016)
  3. #2
    whenever i had a bad ecu, or bad flash etc fans work no coms...so i sugest check ecu!
    Sep 2013
    garage
    ecu is ok , UCH communication on CAN hispeed with UPC module is the problem ...but i do not know witch one is defect ...in my opinion UPC module is going crazy at some moment and is sending over other modules
  5. The Following User Says Thank You to Mr BLACK For This Useful Post:
  6. #4
    Meat-Head's Avatar
    Change under hood fusebox ?180 new plug and pray
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    clusters (27th June, 2015)
  8. #5
    clusters's Avatar
    Mar 2015
    Canada
    "plug and pray" Never heard that before, must be living under a rock. Can I use that?
  9. The Following User Says Thank You to clusters For This Useful Post:
    Meat-Head (27th June, 2015)
  10. #6
    Meat-Head's Avatar
    Yes part of "Plug in and walk away?"
    plug it in if it don't work walk away
  11. The Following 3 Users Say Thank You to Meat-Head For This Useful Post:
    clusters (27th June, 2015), Lexas (4th July, 2015), rideon (28th June, 2015)
  12. #7
    Apr 2013
    Bristol UK
    Hi not sure if your sorted but when you insert the card does the dash beep ? Then the cooling fan run after ? If so in front of the battery the can line to injection computer have corrosion in wire prob green wire, you need to open loom and pull / inspect loom, if you need further help no probs however hope your already sorted
    regards
    lynndon
  13. #8
    Meat-Head's Avatar
    It's French cure one fault gain two exciting new ones
  14. #9
    Lexas's Avatar
    another situation with same symptoms was sorted some time ago, there is a big plug under passenger seat (UK) under carpets. All contacts was green, just touched and about 15 wires comes off... was nightmare to sort, cause most wires was same color, but connects different things.
    Don't Forget Button
  15. The Following 2 Users Say Thank You to Lexas For This Useful Post:
    Meat-Head (4th July, 2015), steelcityuk (9th November, 2015)
  16. #10
    Apr 2013
    Bristol UK
    That plug under pass seat is handbrake can h&l rear door controls & rear window controls. Have seen this plenty and can bring down vehicle can bus system causing weird no related faults in other places
    happy days normal day fixing French cars
  17. The Following 2 Users Say Thank You to renatec For This Useful Post:
    Lexas (25th July, 2015), steelcityuk (9th November, 2015)
  18. #11
    Hi. Thanks for posting this info. My Scenic shows all sorts of faults so I think I need to look into this. Also when I plug in my Clip clone the car goes mad...sometimes.
    Steve.
  19. #12
    Fault ultimately traced to faulty "Accessory Relay" mounted above the glovebox. This 60A relay provides power to the ABS computer, heater fan, radio, etc. When not working faults displayed were - electronic fault, check steering, steering not locked and would take two presses of the start/stop switch to stop the engine. Parking brake wouldn't auto apply as well. Engine fan could continue to run after turning off the ignition.
