Hi. I have problem with Ford Focus MK1, 1.8TDDi. Car was drived at highway and suddenly turned off. After that it won't start, but cranks.
Fault Code: P1608 - Watchdog ...
Have changed fuel pump, and syncronised (coded) with PCM. But again, car won't start. I've installed PCM, Fuel Pump and Key from another car that have worked fine, but also this car won't start. Fault is still there (P1608).
Confusing is that, when I install fuel pump that is not coded, Led indicator not blinks (as it should when it's not recognized), but stay solid and then goes off.
