Results 1 to 15 of 18
    Oct 2014
    Default Mazda 6 - Denso - RF5P - EGR off
    Hello
    Can somebody can EGR off in this ECU ?
    Car: Mazda 6
    ECU: Denso RF5P
    Flash: F29F400BC
  2. The Following User Says Thank You to locarno For This Useful Post:
    marsete (30th June, 2015)
  3. #2
    Jun 2013
    EU
    Unplug egr and remove DTCs
  4. The Following User Says Thank You to morgano For This Useful Post:
    locarno (26th June, 2015)
  5. #3
    Oct 2014
    Quote Originally Posted by morgano View Post
    After EGR unplug, diagnostic shows DTC P0406
    Can somebody remove this DTC ?
  6. #4
    Jun 2013
    EU
    What tool you use to read/write it?
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    I suppose some programmer, it's 29F400 after all...
    On the picture - up and right.
  8. #6
    Oct 2014
    Programmer
    Elnec Jetprog
  9. #7
    Jun 2013
    EU
    So you need dtc an checksum calculated, sorry can't
    Regards,
  10. #8
    Oct 2014
    Regards,
    Do you know software which can correct checksum in this ECU ?
    I modified dump (dtc switches) and write to ECU, but car won't start.
  11. #9
    Jun 2013
    EU
    If i could calc checksum you would have here for download ready file.
    Regards,
  12. #10
    bobolin4o's Avatar
    WinOls 1500 have appropriate checksum for this ECU...
    Regards!
  13. The Following User Says Thank You to bobolin4o For This Useful Post:
    donesko (27th September, 2016)
  14. #11
    bobolin4o's Avatar
    Your file...
    Regards!
    Clear your inbox...
  15. The Following 3 Users Say Thank You to bobolin4o For This Useful Post:
    immokill (2nd June, 2022), locarno (30th June, 2015), morgano (28th June, 2015)
  16. #12
    Oct 2014
    Quote Originally Posted by bobolin4o View Post
    Your file...
    Regards!
    Clear your inbox...
    Cleared.
    If I found correct DTC switches in this file and your checksum is ok this file should be ok. I'll test it.
  17. #13
    marsete's Avatar
    Oct 2010
    SPAIN
    Hi Locarno,my car is mazda 5 with identical ecu,is posible sendme your solution for egr off??Thanks and regards
  18. #14
    marsete's Avatar
    Oct 2010
    SPAIN
    Youe car is posible reprogram sor obd??with piassini soft??Regards
  19. #15
    Oct 2014
    Quote Originally Posted by marsete View Post
    As far as I know this ECU doesn't contains EGR map.
    I simply unplugged EGR and stayed with ori dump in ECU. DTC disappeared for now. I don't know for how long.
    So I don't tested modified file.
    I desoldered flash and read/write using Elnec Jetprog programmer.
    Can't read using Piasini
    betrescudan wrote:
    trasdata ok read
  20. The Following User Says Thank You to locarno For This Useful Post:
    kospoz (10th March, 2016)
