Hello
Can somebody can EGR off in this ECU ?
Car: Mazda 6
ECU: Denso RF5P
Flash: F29F400BC
Hello
Car: Mazda 6
ECU: Denso RF5P
Flash: F29F400BC
marsete (30th June, 2015)
Unplug egr and remove DTCs
locarno (26th June, 2015)
What tool you use to read/write it?
So you need dtc an checksum calculated, sorry can't
Regards,
If i could calc checksum you would have here for download ready file.
Regards,
WinOls 1500 have appropriate checksum for this ECU...
Regards!
NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
If your PM box is full, clean it right now...
Otherwise, your requested file will be deleted... for ever!
donesko (27th September, 2016)
Your file...
Regards!
Clear your inbox...
Hi Locarno,my car is mazda 5 with identical ecu,is posible sendme your solution for egr off??Thanks and regards
Youe car is posible reprogram sor obd??with piassini soft??Regards
As far as I know this ECU doesn't contains EGR map.
I simply unplugged EGR and stayed with ori dump in ECU. DTC disappeared for now. I don't know for how long.
So I don't tested modified file.
I desoldered flash and read/write using Elnec Jetprog programmer.
Can't read using Piasini
betrescudan wrote:
trasdata ok read
kospoz (10th March, 2016)
