Results 1 to 10 of 10
    Mar 2012
    Default Good up to date cable image file virgin uk
    Anyone know of a newish openatv image clone safe please?
    Mar 2012
    Come on guys running version 4.2 build 1 very good but want more like samba client working?
    digicon's Avatar
    Quote Originally Posted by sailsy View Post
    Samba should already be enabled on that image 4.2 if not have a look in the extra's menu Blue Button - Network as it may be switched off by default
    Mar 2012
    yeah found that it checks feeds restarts box but can not enable it?
    digicon's Avatar
    Have you done a software update and then tried again
    Mar 2012
    will try that thought it might break the image after update thanks for reply.
    digicon's Avatar
    Perhaps try another image and forget the update
    Mar 2012
    Thats what i have been after a good image up to date etc?
    digicon's Avatar
    Not sure which dreambox model you have but just had a look over at dreamoem and they have OpenATV 5.0 nightly build for the 800se but only OpenATV 4.2 for the 800
    Mar 2012
    hi again tried the update but was warned may not boot and it did not but i had backed up so no problem!
    i have tried the nightly build which install ok but do not recognise a cable tuner installed it also looks for a twin tuner??
    my box is a dm800 hd se fitted with nutune cable tuner works well on 4.2 but on 5 does not recognize tuner i think i may be nearly there but need a little help!
    think im missing something!
