Page 12 of 31 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 455
  1. #166
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Can i flash it with Jlink or Ulink2? Thanks.
  2. #167
    Jun 2014
    hi to all anyone of you knows if it is possible read and wryte FTDI 232R with programmer? imessed up my galletto 54 chip and i dont find the way out any solution will be acepted tanks
  3. #168
    dadal's Avatar
    Aug 2015
    i cant download flash ( like as show in video), problem is I think CRP level
    how to dissabble CRP2 or 3 ?
  4. #169
    carmageddon's Avatar
    Italy
    v54, dont need to be disassemble, only erased from world (and from lpc with v53)
  5. The Following 2 Users Say Thank You to carmageddon For This Useful Post:
    dadal (23rd January, 2017), phl0at (9th February, 2017)
  6. #170
    dadal's Avatar
    Aug 2015
    finally did it,
    I have now full reworked galetto ( hard & soft )
    Thanks to Fantomel and Please do not forget to give him thanks
    and special thanks to Carmageddon, for his support ( for hardware and software )
  7. The Following 4 Users Say Thank You to dadal For This Useful Post:
    amaflo (25th January, 2017), ankjay (26th January, 2017), beltronics (29th January, 2017), pike (29th January, 2017)
  8. #171
    Dec 2016
    Hello friends! I have a problem with the software "V54 for 0475 Win all." I'm with Win7 Os. Of ten attempts to start the program it runs only once. I get the following error. Can anybody help me to resolve the problem? Thanks!
  9. #172
    Nov 2015
    Lublin/poland
    hello please me send dump ept and eprom from adapter usb ttl
  10. #173
    Jan 2017
    I have bought a chinese clone V54 latest claimed 2017 version. I have done all the tricks possible to make this tool work. I have written n number of ept files till now, followed all the different processes like setting the system date to 1/1/2013 , installing correct drivers and what not. But this tool does not budge. When i connect to any of the cars the software opens properly, it shows tool no 0386, it shows correct voltage. But when i select the driver and try to connect to any of the cars it throws an error as shows in the picture
    Attention!! Send File C:\FGTECH\EOBD2_LOG\_ebod2_XXXXXX_ERR.gal to support@fgtechnology.it
    I have been breaking my head over this tool since 5 days now without any success. I have not done any hardware changes yet. I have ordered a USB to TTL converter to write MCP with 0475 version now. But i doubt if that will work for me.
    Request all the senior members and expert to please help me on this.
  11. #174
    Jan 2017
    I followed all the software changes suggested by Fantomel in the opening post. My tool now shows 0475 and when i open the 0475 version EOBD2 i see correct voltages etc. But still my tool cannot read any ecus
    I am trying only through OBD port, i do not need BDM feature. Can someone please point out what controls read thru OBD and why i get the error mentioned in the above post
  12. #175
    Jan 2017
    Sorry, i dont get it. what do you do with these files? and whatsthe purpose?? i am new to this so excuse the dumb questions
  13. #176
    Dec 2012
    Quote Originally Posted by Suv4x4 View Post
    did you check over your obd cable on dsub & obd side ?
  14. The Following User Says Thank You to gazvts For This Useful Post:
    Suv4x4 (9th February, 2017)
  15. #177
    dadal's Avatar
    Aug 2015
    do you use obd adapter ?
    this one:
    and try it with an other USB cable ( not original of galetto),,I use an better usb cable
  16. The Following User Says Thank You to dadal For This Useful Post:
  17. #178
    Jan 2017
    Thanks a lot Dadal and gavts , i changed the USB cable. the connectivity to the outer casing was missing. Now the tool works perfectly. The best part is now its 0475 version. Was able to read and write a Delphi DCM 3.2 ECU
  18. #179
    WALES
    I can't get this to work in Windows10, does anyone have a solution?
    see pictures
    wbr
  19. #180
    Dec 2012
    if yours still 0386 firmware it will not work with the software you have installed . need to either flash it with 0475 fw or try running aes version on it which i personally never tested that on win 10 system
  20. The Following User Says Thank You to gazvts For This Useful Post:
    shooting (13th February, 2017)
