Page 24 of 31 FirstFirst ... 141920212223242526272829 ... LastLast
Results 346 to 360 of 455
  1. #346
    May 2017
    Greece
    U will disconnect ttl , remove cables & jumper from fgtech (with power disconnected) and then with fgtech connected u will write ept/eeprom
  2. The Following User Says Thank You to reselie For This Useful Post:
    joker01 (27th February, 2019)
  3. #347
    Jan 2019
    Best Country of the world, GR
    only with the standard cable of galletto (USB 2.0 A-Male to B-Male cable) which connect to pc...
  4. The Following User Says Thank You to gas43 For This Useful Post:
  5. #348
    Jan 2019
    Quote Originally Posted by morgano View Post
    Is possible use 90% of v53 functionality, just jtag not possible because obviously hw is missing.
    But full working OBD, and BDM updated support to v53 is possible.
    successful upgrade v48 0475! Tested tricore vag med17.5 read/write.
    But I have incorrect volt indication. at software 10.3 Volt but at the red cable 12.3 volt (multimeter tested). The error of voltage is in software.
    older same case (post 1023) https://www.digital-kaos.co.uk/forum...letto-2/page69
    I dont understand, Which resistor sould I change? near to D1? same pcb https://www.digital-kaos.co.uk/forum...4&d=1356199044
    maybe, like this? https://www.addicore.com/82k-Ohm-1-4...-p/r6182ks.htm
  6. #349
    Jun 2012
    Quote Originally Posted by PaoloDigital View Post
    I update tool 475 but i have error crash , inn win7 64bit , you have solution pacth or procedure
    Same problem. Did you solved it?
  7. #350
    May 2017
    Greece
    I also have same issue. Win xp and win7 32bit works OK , on win 64bit (both native 7 or win10 with compatibility mode) i get same Crash report
    Free ecu_software 2,5GB : https://mega.nz/#!mBwmWQiB!UTDEKhZJc...qxXFBdoa9q0KIQ"As we enjoy great Advantages from the Inventions of others we should be glad of an Opportunity to serve others by any Invention of ours, and this we should do freely and generously."
  8. #351
    carmageddon's Avatar
    Italy
    i use without problem fg v48 and v53 on XP and 7 32/64 bit
  9. #352
    Jun 2012
    Quote Originally Posted by carmageddon View Post
    I have this problem with V54 0475 on Win7 64bit.
  10. #353
    Jun 2012
    Tried with fw 0386 and aes soft, it works in win7 64bit. What's the difference between 0386 and 0475?
  11. #354
    Italy
    0386 = june 2012, 0475 = december 2012
  12. #355
    Jun 2012
    Understand.
  13. #356
    Jan 2019
    Quote Originally Posted by cawadany View Post
    Did you use fix tool? ftreadwrite and mprog? if not work again, maybe it is microsoft visual issues...
  14. #357
    Jun 2012
    Quote Originally Posted by gas43 View Post
    Yes, tried with fix tool. I think it's a windows issue. The tool, with 0475 and soft v54, works without problem in a desktop with win 7 32bit. In the netbook with win 7 64bit, the app crash.
  15. #358
    joker01's Avatar
    Jan 2018
    sorry guys.......
    which file should I use for flash ????
    from what I understand ??? dtr what is it ???
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  16. #359
    Jan 2019
    Quote Originally Posted by joker01 View Post
    sorry guys.......
    I use "lpc2119 0475 19200.hex"
  17. The Following User Says Thank You to gas43 For This Useful Post:
    joker01 (9th March, 2019)
  18. #360
    Jan 2019
    Then I think, the notebook may not meet the specifications.
