Page 16 of 31 FirstFirst ... 6111213141516171819202126 ... LastLast
Results 226 to 240 of 455
  1. #226
    fantomel's Avatar
    Mar 2009
    Us
    First of all, good USB cable and 2nd of all has been known that some ftdi chips are not ok, or they break. So if after you write hex to lpc and dump from ftwrite it's not working, then replace ftdi and will work.
    Also said 100 times, just to be safe, try and manual install driver for interface from installed program folder (even if you interface is ok in device manager) to be 100% sure it that driver and not another installed. Make ftwrite and run program.
    The one without date back in fact at run applies again ftwrite part, so if loader does not make it , you make it before run.
    If still does not work change FTDI chip.
    If you like my post and it helped you please press THANKS.
  2. The Following 4 Users Say Thank You to fantomel For This Useful Post:
    antonino8666 (7th October, 2017), dob12 (12th February, 2021), eeee10 (26th December, 2017), ntom (9th September, 2017)
  3. #227
    Aug 2014
    Thanks for replying but I'm totally not convinced about 2 things.
    1) if i write back everything from 386 all works fine. So it seems to me a sw issue not usb or ftdi.
    2) is it normal or not that ftreadwrite is not able to write last eeprom part?
    About drivers of course they are from sw folder after setup.
  4. #228
    Aug 2014
    Quote Originally Posted by lsdlsd88 View Post
    My problem is when I open the software it shows me low voltage and buttons are not active.
    In my case I did everything correctly, the solution was deadly simple.
    AFTER open the program and see grey buttons, unplug and replug usb cable.
    magically everything starts working -.-
    to confirm, it is NORMAL that your eeprom is not completely written.
  5. The Following User Says Thank You to lsdlsd88 For This Useful Post:
    Stelaras26 (3rd July, 2020)
  6. #229
    carmageddon's Avatar
    Apr 2010
    Italy
    some tools have this problem, is not question of fw, you need always to do this sequence and work.
    i rebuild one of this with all new components and MY fw and SW and same problem.
  7. #230
    Hi, galletto 04754 works on windows 7 64bits ?, I have problems with one that works, well in 32 bits but in 64 it does not open the program, apart from that when the program opens, I have to wait a few seconds for the relays to ring Then it opens completely and the gray protocols no longer appear
  8. #231
    May 2013
    Hi.
    So my FGTECH is 0386.
    I read 2 or 3 ECUS with it. Should I update to the 0475? What is the difference? Is the 0475 any better? More reliable and support more ECU?
    Also what hardware changes to make to the V54 FGTECH china to improve it?
    Thanks alot
  9. #232
    Member kingarthas's Avatar
    Nov 2012
    Finally some good info for 0475 EU version...
    FGTECH 0475 Added New vehicle and ecu type Than 0386 Version:
    11/12
    OBD driver SSang-yong Del-phy DCM3.7 Read/Write, Checksum
    11/12
    OBD driver for Fer-rari 458 Italia MED9.6 Ecu Master and ECU Slave Read/Write, Checksum
    10/12
    OBD driver for Fi-at/Al-fa/Lan-cia Twi-nair/Mult-iair 8GMF and 8GSF Read/Write, Checksum
    10/12
    OBD driver for Ma-zda 5, Ma-zda 6 2.0 Diesel ECU RF8x Read/Write, Checksum
    10/12
    OBD driver for Ma-zda 5, Ma-zda 6 2.0 Diesel ECU RF7x Read/Write, Checksum
    09/12
    OBD driver for Sim-os 10.xx VA-G 1.2 TSI Read/Write, Checksum
    09/12
    OBD driver for CRD 3.xx Merc-edes 2200 CDI Read/Write, Checksum
    09/12
    Simos PCR2.1 VA-G 1.6 TDI Unlock Boot Tool - Read/Write EEPROM
    09/12
    OBD driver Sim-os PCR2.1 VA-G 1.6 TDI Read/Write, Checksum
    08/12
    RSA recognition Peu-geot Bip-per
    08/12
    RSA recognition Citr-oen Ne-mo
    08/12
    OBD driver Driver for writing Bo-sch EDC16C34/5 Peu-geot Bip-per Read/Write, Checksum
    08/12
    OBD drive Driver for writing Bo-sch EDC16C34/5 Citr-oen Ne-mo Read/Write, Checksum
    07/12
    OBD driver Del-phi DCM3.5 for Ta-ta Sa-fari Read/Write, Checksum
    07/12
    Checksum recognition for DCM3.7 Ssan-gyong
    07/12
    Checksum recognition for DCM3.7 Op-el and Sa-ab
    07/12
    Checksum recognition for DCM3.7 Ki-a and Hyu-ndai
    07/12
    Boot Visteon ST10F275 RX-TX Mode
    07/12
    Boot ME7.9.10 ST10F275 RX-TX Mode
    06/12
    Checksum recognition for Denso Sub-aru Tri-beca
    06/12
    Boot Mitsu-bishi MH7203 Hyu-ndai
    06/12
    Checksum recognition for Denso Nis-san L200
    06/12
    Checksum recognition for Denso Nis-san X-Trail
    06/12
    OBD driver Op-el Simtec75 CAN Read/Write, Checksum
    05/12
    OBD driver Pors-che SDI3 CAN Read/Write, Checksum
    05/12
    Cor-vette Utility CAN for change VIN, Code Align, Erase Errors
    05/12
    Corette Utility VPN for change VIN, Code Align, Erase Errors
    05/12
    OBD driver Reault SID305 CAN Read/Write, Checksum
    05/12
    OBD driver Masrati ME9 CAN Read/Write, Checksum
    04/12
    Tool Boot Hitaci Phase 3
    04/12
    Tool Boot Hitaci Phase 2
    04/12
    OBD driver Fi-at ME17.31 CAN Read/Write, Checksum
    04/12
    Boot Mits-ubishi for L200 MH8102F
    03/12
    Boot Mitsu-bishi for Lan-cer EVO MH7202
    03/12
    Fi-at MJ8DF CAN Serial Injectors
    03/12
    02/12
    OBD driver Fi-at MJ8DF CAN Read/Write, Checksum
    02/12
    OBD driver Fi-at MJ8DF K-line Read/Write, Checksum
    02/12
    OBD driver Merc-edes Del-phi CRD2.xx CAN Read/Write, Checksum
    01/12
    OBD driver Fo-rd Del-phi DCM3.5 CAN Read/Write, Checksum
    01/12
    OBD driver PS-A Delp-hi DCM3.5 CAN Read/Write, Checksum
    01/12
    OBD driver VA-G Sim-os 3xx Boot mode 29F400 C167 Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 9.1 Boot mode 29F400 C167 Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 7.1 Boot mode 29F400 C167 Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 33 K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 32 K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 3PG K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 3PE K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 3PD K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 3PC K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 3PA K-line serial Read/Write, Checksum
    12/11
    OBD driver VA-G Sim-os 9.1 K-line Read/Write, Checksum
    11/11
    JTAG MPC55xx
    10/11
    New password Triore Tprot V08-10
    10/11
    OBD driver Ren-ault Val-eo V40, Read/Write, Checksum
    10/11
    AUD Ren-esas
    10/11
    Boot Ren-esas
    NEW for VAG SIMOS PCR2.1
    NEW JTAG - BDM - MOTOROLA - FREESCALE -
    NEW JTAG RENESAS
    Freescale MPC 5553/5554/5565/5566 NEXSUS PORT New IAW MJD 8F2
    Mair 8GMF New Delphy DCM3.5xx DCM3.7xx TRW.
    Motorola Freescale MPC 555/556/561/562/563/564/565
    Motorola MC 68332 - MC YQQCU - MC 68377 Trionic 5/7/8 GM-OPEL-SAAB
    Motorola MC 68376 Campi 01 Lamborghini - Lotus
    Motorola MC 68336 MEMS D5 ROVER
    Motorola ZC 439615 - ZC 439507 IAW FIAT - VAG
    New Line OBD protocols VPM GM Hummer-Corvette-Munstang-Blazer-Cadilac
    New Line OBD protocols Tx - Rx Subaru - Mitsubischi - Hitachi - Denso ecu
    NEW JTAG - BDM - MOT - FREESCALE :
    Freescale MPC 5553/5554/5565/5566 NEXSUS PORT New IAW MJD 8F2 - Mair 8GMF
    MOT Free scale MPC 555/556/561/562/563/564/565
    MOT MC 68332 - MC YQQCU - MC 68377 Trionic 5/7/8 G-OPEL-SAAB
    MOT MC 68376 Campi 01 Lambogini - Lotus
    MOT MC 68336 MEMS D5
    MOT ZC 439615 - ZC 439507 IAW FIT - V A G
    New Line OBD protocols VPM Humer-Corvette-Munstang-Blazer-Cadilac
    New Line OBD protocols Tx-Rx - Sbr - Mitsubischi - Hitachi - Denso ecu
    All EDC17 MED17 is good always modify with Boot Mode .
    Boot Mode System:
    Sak TC1766
    Sak TC1767
    Sak TC1792
    Sak TC1796
    Sak TC1797
    I have a scalpel, I want to become a surgeon, what else do I need?
  10. The Following User Says Thank You to kingarthas For This Useful Post:
    lsdlsd88 (2nd October, 2017)
  11. #233
    Top Poster youk's Avatar
    Nov 2009
    france
    change the chip FTDI you have a fake FTDI
  12. #234
    Mar 2010
    OK but 0386 work OK
  13. #235
    Mar 2016
    I update tool 475 but i have error crash , inn win7 64bit , you have solution pacth or procedure
  14. #236
    Nov 2009
    france
    Quote Originally Posted by Marek_Spy View Post
    OK but 0386 work OK
    the flash software the ftdi at each execution (for tool-475)
  15. #237
    Aug 2014
    Quote Originally Posted by youk View Post
    and why this was not needed for 386? isn't possible to disable this execution?
    anyway I can live with unplug/replug, not a big issue ONCE YOU KNOW you have to xD
  16. #238
    Mar 2016
    Quote Originally Posted by asix View Post
    Hello friends! I have a problem with the software "V54 for 0475 Win all." I'm with Win7 Os. Of ten attempts to start the program it runs only once. I get the following error. Can anybody help me to resolve the problem? Thanks!
    Attachment 424734
    Hello friend i resolution this problem ,with battery monted , in laptop HP compact win7 64bit, not battery unmonted error, battery laptop monted not crash eobd2.exe .my experience.
  17. #239
    Newbie pedroclio's Avatar
    Dec 2017
    lyon
    merci pour le partage du logiciel
  18. #240
    Sep 2013
    Use fgtech in Notebook or netbook?
