Becker Be 2580
Serial number: 15094964
Is it possible to get code from serial or do I have to read the flash memory (AM29F800BB) ?
Becker Be 2580
the info you have posted is not enough to get factory codes
required AR + 10 digits + "/" + 2 digits
and helpful is 5wkxxxxx serial number
all to be accurate cheers
It's here somewhere ( a blind man looking for a black cat in a dark room that is not there)
kappa1 (3rd July, 2015), masterskay62 (30th June, 2015), redtop (30th June, 2015), REZON (30th June, 2015), Zann (1st July, 2015)
Thank you for your quick answer! I'll try to do my homework better!![]()
REZON (1st July, 2015)
This is the label of the unit. Where can I find the additional information?
see if there is a gps module in the boot/trunk with info cheers
this is a typical input for example AR2200041913/01
generates 2 code
navi 6052 radio 0286.
I wonder if your is just a normal becker algo
here are some becker codes to try based on your serial
4 digit 1283
5 digit 4 preset 31241
5 digit 5 preset 31231
5 digit 6 preset 51221
cheers
masterskay62 (1st July, 2015), mcd76 (1st July, 2015), redtop (1st July, 2015), Zann (1st July, 2015)
Thanks! Will give it a try!
Unfortunately that was a no go.
We'll see if we can find the 14 digit code somewhere, otherwise I understand you can read the flash memory and get the code from there?
Hi Clydey,
I wonder if you could help me too - to avoid lots of cursing with desoldering braid to get my Flash off!
Unit is a Becker 2580, with attached 5WK 78209
Alfa Serial number is AR2090001806/02
Becker ser no Y5043489
Many thanks
Paul
yes I can paul but only can do one pair a day I will do yours first thing tomorrow
unless you can be helped by another poster cheers
xtoni (21st September, 2015)
clydey (21st September, 2015)
[QUOTE=paul1569;2603513]Hi Clydey,
these are the codes as it left the factory
try
navi code 7558
radio code 3199
sometimes codes are visa versa ie navi code is radio code ect
if only 1 code works drop power to units repower and try again cheers
update by pm from paul1569
codes worked
