Here your file...
Regards,
Ps:Clean your inbox
Here your file...
Regards,
Ps:Clean your inbox
Did you clear dtcs and disconnected egr valve?
Regards,
Attempting key decision and disconnecting the socket of the EGR , I think it not will work. Stops the turbine and valve
Opps, then i can't help mate, because this time was the correct switch.
Try my decision. Tove EGR is off. Do not disconnect the connector of the valve
1037351885_EGR-off.rar my solution is ok
You dump EGR off , passw PM
Best regards
stanislav georgiev (5th July, 2015)
Yes you are right, is active 4% but the vacuum is weak and can not open the EGR . Funny how none file does not work for you
