Results 1 to 15 of 15
Hybrid View
    Nov 2009
    You wrote 'damaged both displays' - does it mean other things on dash work ok (gauges, lamps..)? If you can connect to dash with opcom, then you can easy adapt you new used dash.
    Dec 2018
    yes I broke both display cables by opening the case. (Shame on me ). You mean I can adapt the new used dash even I don't know the S. PIN of the new used one ? I would give it a try but my fear is that if I reset my current dash some error occurs while reset and then nothing works anymore- Thats the reason I haven't tried it yet. The sequence of reseting and adapt is important afaik
    And yes all other things like gauges, lamps, signals are working fine. I drive without any display since more than 3 years :-(
