cart10 (12th January, 2019)
need help
now my goal is to buy xp-005
who will help?
Done,
Any tips Rafal ?
try this one. it is last one. if will not work wait for answer from dragon
need help
who will help?
lets do this, 10mins
that was a long 10mins, no my friend , still small fault, light on,
Thank you very much for your time today, i really mean that, thanks , ill have to wait for dragon100 as you said
If helped +Thanks & +Reputation
cart10 (13th January, 2019)
Answear for your pm ...
Best regards.
Dragon
yes , only the p/s seat belt was fired as soon as i changed that it came out of limp mode,
only error i get is E698 seatbelt pretensioner,
im starting to think it could be the satellite on drivers side, but no error msg comes up for this, im using peugeot plant and diagbox,
disconnect seatbelt pretensioner then use 3 ohm resistor just for check and report back
need help
who will help?
just tryed tamers and no worked, i tryed the Other file of clear one,
check also wiring (plug ) under seat
need help
who will help?
