    chris0200
    Guest
    Default Access to DK only if I am using a VPN
    Over the last week I have not been able to access kaos as all browsers tell me timeout.
    I have flushed the dns and the cache from the browsers, no help. The only way I can access is if I use a VPN via Holland. Any ideas?
    chris0200
    Guest
    Still an issue any ideas???????????
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    i will leave the boss man a message, think its something only he can sort out.
  4. The Following User Says Thank You to gmb45 For This Useful Post:
    chris0200
    Guest
    Now working again after upgrade to windows 10, not a clue why or what caused the problem.
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Upgrading the browser doesn't explain a block unless it was cookie or cache related. Your ip can't have changed unless you've rebooted your modem so you can't be blocked in the firewall.
    Any more issues, let me know please.
  7. The Following User Says Thank You to Devilfish For This Useful Post:
    PremierD (21st September, 2015)
  8. #6
    chris0200
    Guest
    Quote Originally Posted by Devilfish View Post
    Still OK at the mo, not sure what happened.
