Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 86
  1. #16
    DK Veteran gtmech's Avatar
    Hell
    Quote Originally Posted by autoelek View Post
    Hi I have the same receiver box in Alfa 156, I have read HC05 from this box and by me code is 10929 (EF6D6 xor FFFFF), but when I want to program remote I can see wrong password ... Can someone help ? I attached dump file from HC05.
    10929 is correct, restart software and try again
  2. #17
    Jun 2012
    Hey guys, it looks like I have something extra again.
    I read the 0D60J (HC05B32) chip with XPROG-m, but I have one 0 at the place where the code should be. What does the 0 translate to? I tried reading it in different adapter, but I got the same content from chip.
    My unit looks like this:
    And the code is here:
    Thank you for any info.
  3. The Following User Says Thank You to bajticzek For This Useful Post:
    Meat-Head (30th September, 2018)
  4. #18
    Jun 2012
    Quote Originally Posted by gtmech View Post
    Code 10929 is 100% not good, testing with magneti marelli logic and fiat examiner, I don't have idea how to calculate good code
  5. #19
    mikajna's Avatar
    Mar 2015
    @Autoelek your PIN CODE is 92970 100%...try and report
    @Bajticzek your PIN CODE is 93900 100%...and you to mate, try and report
    Best Regards
  6. The Following User Says Thank You to mikajna For This Useful Post:
    autoelek (27th August, 2015)
  7. #20
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    What did you use to read HC08?
    Dumps are all wrong...
  8. #21
    Jun 2012
    Quote Originally Posted by mikajna View Post
    Best Regards
    I tested code and car was accepted this code, I confirm that code 92970 is good and matched to file "hc05=2015-08-21.rar" which I was attached in previous post ! THANKS mikajna
  9. The Following User Says Thank You to autoelek For This Useful Post:
    mikajna (27th August, 2015)
  10. #22
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by simaservis1108 View Post
    No Simo, MCU is HC05B32...vidimo se uskoro druze
  11. #23
    Aug 2013
    Serbia,Belgrade
    My mistake,HC05.
    Dumps are shifted,must be reading bug.
    If we shift them two positions backwards one pair we get correct position for pincode.
    I guess that is why you have two extra 00 in the beginning of your dump.
  12. The Following User Says Thank You to simaservis1108 For This Useful Post:
  13. #24
    Jun 2012
    mikajna and simaservis1108 - Thanks for the answer. I will test the code today and report. It makes sense the positions are wrong - it really looks like the code is shifted by one word.
  14. #25
    Jun 2012
    Ok, so the code is not working. I login via AlfaOBD with code 93900, I try to store new remotes and AlfaOBD immediately says the code is wrong, so the unit doesn't accept the procedure... Should I buy UPA to read the chip? I have XPROG-m, as I said earlier, so maybe the reading via this was wrong... I also have CarProg 4.01, do you think this box can read the HC05 without any problem? Or should I buy the UPA and don't risk messing the chip with CarProg?
  15. #26
    Aug 2013
    Serbia,Belgrade
    Best is ETL.
    I have for every MCU family.
    Never had any problems.
  16. #27
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by bajticzek View Post
    Mate I just check your whole dump from image you had post here...and your dump is not good, maybe is because programmer which you used, as said mr.Sima, really I dont know, just know that row 00000060 must have fixed bytes, not all but almost all...and your dump dont have it.
    Read that MCU again, and post here dump...than we will see is problem in reading or mcu is corrupted
  17. #28
    Aug 2015
    I have problem with my dump. The pin it's 71609 but it not working. I read mcu with xprog. Maybe I doing something wrong. Can somebody check my dump and write the correct pin?
    dump 156.rar
  18. #29
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by cyniux View Post
    dump 156.rar
    Your dump looks good, and PIN code is same as you try...71609 you can try to read again with some other tool
  19. #30
    Aug 2015
    Thank mikajna for check this file. I have only xprog. Today I check this code with examiner maybe it's work. I try only with AlfaObd and no succes.
