I buy used central lock reciever and desolder hc05 from it, read with xprog and extract the pin from eeprom. Next solder hc05 and programmed with pin 2 used remotes.
I try to read hc05 on board but i cannot read it. If you want read without desolder you must desolder and lift only this legs that will be needed for programming.
Wysłane z mojego GT-I9100 przy użyciu Tapatalka
I am not an idiot. I can solder very well. If I can solder chips with leg pitch of 0.025 inch with ease, do you really think that HC05 with 0.8mm pitch would be a problem? So I don't really get your "advice".
Nevertheless, my UPA came today and I read the HC05 again. Content of the chip is attached, the bytes on needed positions are the same. Verify is OK, so the content must be read without a problem. It looks like I have some other version of central locking unit than you, guys...
And if anyone thinks the chip is damaged, it is not, if I solder it back to the unit, central locking works flawlessly.
read_upa.zip
You have maybe the same problem. My hc05 looks good i desolder it read and solder. Central lock and remote are working but i can't use readed pin. Sometimes the eeprom in hc05 are broken and you cannot read it properly. I doing the 606693420 siemens box. In the first box the eeprom in hc05 are broken. I buy the same box and read it without any problem. I do 606693420, 60653303, 60670721. All this boxes I do with simple xprog. Only my first box have a broken eeprom and I cannot properly read it but central lock and remote work good. Maybe you try with another box, it's very cheap.
bajticzek (22nd October, 2015)
These are photos I have taken before I started to do anything with the board, to be sure I solder everything back in place as it was.If you are reffering to white/yellowish places around some legs, it's oxidation, because this unit is located in a trunk. Sometimes for as long as eighteen years... But I think a "skilled" electrician like you would notice that. Maybe you are not and you are just acting like a complete douche.
And as cyniux said, I will use another module. Friend has got few of these in his garage. I'll compare the P/Ns and will see.
Mate, try to write some else dump in your mcu...this thread have a lot of dumps, try with any dump and already calculated pin code, than program your remote and new remote, that will work if everything other is ok.
best regards
Mikajna you are right. I try the same method. My hc05 after write the another dump is silent but it is maybe broken.
This module have a few version of firmware and hardware. The module uses a few types remote with one, two and three buttons. If he write a wrong dump the module dosen't work or sometimes work but without all function.
I see a oryginal three button black remote with button door, window, and trunk in alfa romeo 156 3.2 v6 '04
Alfa Romeo 156 never had 3 button remote.Only 2 button.
Cromwe11 (22nd October, 2015)
147> used a three button remote that has lock/unlock/trunk. Never seen any Alfa remote with a window button. I work with Alfa's every week and have owned every model of 156 going from 1.8ts to 3.2GTA. Never seen a three button remote on any 156. Can't find it in the Alfa parts catalog either. What market was that 156 from? Don't suppose you have the vin so I can look it up?
Sorry you are right. I ask my friend who have this remote and he talk this remote have a three buttons. It is oryginal remote but reciever is a not oryginal. He use a lock button to open/close doors, unlock button for open/close windows, and trunk button.
Sorry friend for my mistakes
Best regards
Clearly the chip has been soldered before by hand and clearly that is flux residue, but if this is before you touched it then theres no need to get get so defensive! I was giving you advise that soldering like this could cause problems if that is not your soldering then whats your problem.
Also by bad soldering I am not referring to the residue I'm talking about the bad soldering.
