Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 85
  1. #61
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Dump corrupt.
    Program other working dump with known pincode and program remotes.
  2. The Following User Says Thank You to simaservis1108 For This Useful Post:
    Fallen (10th November, 2015)
  3. #62
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    help remote pin code
  4. #63
    Oct 2015
    pin code 12931
  5. The Following 2 Users Say Thank You to rokibar For This Useful Post:
    alclot (11th December, 2018), audiopoint (23rd March, 2016)
  6. #64
    mikajna's Avatar
    Mar 2015
    Guys, does somebody have pinout or wiring diagram of Alfa Romeo Siemens central locking and for Lancia Lybra Siemens central locking? Thanks
    Послато са GT-I9060 уз помоћ Тапатока
  7. #65
    p1et's Avatar
    Oct 2013
    All Alfa 156 remotes need different PIN code to program than the PIN code on the code card / in immobox? Advanced diagnostics says 'some of' require different PIN.
  8. #66
    Mar 2014
    West Sussex UK
    Quote Originally Posted by p1et View Post
    Pin for immobiliser and remote are always different on 156. Code card only has the pin for immobiliser not the remote.
  9. The Following User Says Thank You to Cromwe11 For This Useful Post:
    p1et (3rd October, 2017)
  10. #67
    Aug 2015
    I don't want to open new thread for this, is "latest" alfas 156 , year 2006, also uses this separate remote control receiver? And where exactly is located if yes ? thank you
  11. #68
    lpf01's Avatar
    Oct 2013
    If equipped with BSI it have the same pin for remote, if its the older system with immo box it requiresdifferent pin for remote.
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  12. #69
    Mar 2014
    West Sussex UK
    Quote Originally Posted by dtip View Post
    If its saloon then top of trunk under the parcel shelf in the centre. If its SW then behind carpet above wheel arch next to the fuel filler neck.
  13. The Following User Says Thank You to Cromwe11 For This Useful Post:
    mikajna (8th December, 2018)
  14. #70
    Mar 2016
    serbia
    Default lybra remote pin
    help remote pin lybra thanks
  15. #71
    Aug 2018
    Hi, I just joined the board to share some information about the Alfa 156 remote ECU. I managed to build my own EEPROM code extracotr, and here is the dump I got. I don't seem to be able to get the PIN code to work with AlfaOBD though. I can connect, and switch the unit between Alarm mode and Doors mode, but I cannot seem to add a remote. Please save me from reverse engineering the entire 16k ROM on this chip to see how it works!
  16. #72
    HeXeN's Avatar
    Mar 2015
    I urgently need pin code Alfa 156 2006
    is this 02670? I will try
  17. #73
    Oct 2015
    Quote Originally Posted by HeXeN View Post
    yes 02670 correct code for remote programming
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  18. The Following 2 Users Say Thank You to rokibar For This Useful Post:
    HeXeN (7th December, 2018), mikajna (8th December, 2018)
  19. #74
    Jul 2020
    help remote pin alfa romeo 156 2003 thanks
  20. #75
    HeXeN's Avatar
    Mar 2015
    Quote Originally Posted by alenfox View Post
    pincode 82168
