Results 1 to 7 of 7
    Dec 2013
    Default anybody know how to program the toyota avensis?
    the kd900 can make the remote for new toyota avensis.
    anybody tried it ?
    and do u know how to program it?
    and anybody tried the kia ceed again?
    autochei's Avatar
    Mar 2013
    romania
    kia ceed i try it again without succes
    Atex31's Avatar
    Feb 2011
    UK
    Hi Jimmy,
    What brand is the Avensis remote please, is it Valeo?
    Here is the manual procedure for 2005 onwards.
    NOTE : Make sure the drivers door is OPEN and UNLOCKED and the key is out of the ignition.
    1. INSERT and REMOVE the key from the ignition, do not turn.
    2. CLOSE and OPEN the drivers door twice within 40 seconds.
    3. INSERT the key into the ignition and remove it again.
    4. CLOSE and OPEN the drivers door twice within 40 seconds again.
    5. CLOSE the door.
    6. Insert the key into the ignition key cylinder.
    7. Turn the ignition switch from LOCK to ON and back to LOCK at about 1 second intervals
    to select the desired mode.
    NOTE : 1 time for ADD.
    NOTE : 2 times for REWRITE.
    NOTE : 3 times for CONFIRMATION.
    NOTE : 5 times for PROHIBITION.
    8. Remove the key from the ignition.
    9. To confirm your selection of all modes except CONFIRMATION, the power locks
    will now cycle LOCK to UNLOCK the number of times corresponding to your selection.
    NOTE : If CONFIRMATION mode has been selected, the power door locks will now cycle
    (in 2 second intervals) the number of times corresponding to the number of transmitters currently registered.
    NOTE : Opening the door will complete the procedure.
    NOTE : If PROHIBITION mode has been selected, opening the door will complete the procedure.
    10. For ADD or REWRITE, within 20 seconds of Door Lock confirmationfollow :
    (a) Press both transmitter LOCK and UNLOCK buttons simultaneously between 1 and 1.5 seconds
    and release.
    (b) Within 3 seconds of step (a), press the transmitter LOCK button for more than 1 second and
    release.
    (c) If the transmitter has been successfully programmed, the power locks will cycle LOCK to UNLOCK.
    once at this time. If there are problems with the procedure used up to this point, the locks
    will cycle twice, in which case you must go back and repeat the above steps (a) and (b).
    (d) If multiple transmitters are to be programmed, repeat the above steps (a) to (c).
    11. Open the drivers door to complete the procedure.
    Last edited by Atex31; 8th July, 2015 at 09:40 PM. Reason: Added manual procedure.
  4. The Following User Says Thank You to Atex31 For This Useful Post:
    purdy (9th December, 2015)
    west mids, uk
    keydiy toyota RAV4 2006 remote working good
    Also, hyundai i10 2009 working, but only MVP would program it.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    Atex31's Avatar
    Feb 2011
    UK
    Quote Originally Posted by ninja123 View Post
    ninja
    Was the Rav4 a Denso remote?
    Dec 2013
    Quote Originally Posted by Atex31 View Post
    Hi Jimmy,
    5. CLOSE the door.
    and release.
    release.
    it is new valeo.
    the old valeo avensi not cracked. but hope soon.
    looks diamond style
    west mids, uk
    dont know for sure, I just tried the first one on keydiy menu, 'old toyota' with a number like 54032 or something like that!!
    ninja
