i tibnk there is no solution for taht
Block egr and remove dtc or disconnect valve and remove dtc done many times
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Hi, and could You remove DTC? If I post dump?
THX a lot
Yeah DTC remove is possible but we needed have dump and all DTC's before and after disconnect valve.
After disconnect valve - P0405
Before - P0404
in delphi there is not posible disable dtc. ECUtuners go to home
I don't check file, but right this is old ford, even problem with DPF is not so easy.
Only from Delphi DCM3.5 DTC can be remove
Which tool you read mondeo?
morgano (12th July, 2015)
If you can do it , do it to Waldi1979, and we will see your results...
there is no damos to this kind of ECU. The true is that you are liar....
Lol because you can't find damos to it does not mean it doesn't exist. I have done dtc on ford Delphi, eecv and visteon for many people on this forum. Anything else?
morgano (15th July, 2015)
