Results 1 to 3 of 3
    Austria
    Default RENAULT MEGANE dpf off
    Hello, please help me remove dpf from renault megane 1.9 dci with 130 hp.
    RENAULT Megane 1.9 dci.rar
    thanks in advance!
    mihaiservice's Avatar
    http://www.quick-tuning.com
    dont know wich kind of tool you have used to read the file,the problem are when you are writing the file
    before write any file you must read injectors coding value and after you have write the flash file you must to recode again all 4 injectors
    here you have dpf off file,two dtc remove it from file :
    P1435-Failure of particle filter regeneration
    P2002-Diesel particulate filter below threshold
    check PM for the pass
    Mike
    Austria
    i read with kess, and read injectors code...
