I've deleted my favourite list from v8s can anyone tell me how to get it back or send me a file plz 28.2
cheers
cheers
Just reinstall either AJ's list or CWAITE's list from the stickies above.
The 2nd post in AJ's thread has instructions for installing.
I've done all that even updated firmware but still no favourites list i wonder if its to do with the mac book I'm using or should i use a window machine ?
It shouldn't have anything to do with the machine you use to download.
As long as you transfer the channel list to a memory stick (or USB HDD) & then Update by USB, tHen it should work. It should take around 10 seconds to transfer the TP_prog.dbs file to the box. When you press the "info" button afterwards, it should show "OK".
Try unzipping the channel list if it zipped into a folder
