    credoline's Avatar
    Србија
    Default Laguna 1.9 DCI DPF off
    Please, i need help to make this ecu with DPF off. I need to help me someone who knows what is doing. I have Volta, ESUSafe and can i get solution from Swiftec, but somehow i do not believe in those softwares.
    Can someone help me who have real and tested solution for this DPF off ? Car is Laguna II 1.9 DCI, ecu is Bosch 0 281 014 352, software is soft 1037387307. Reeading is full, flash, eeprom and mpc.
    Thank you
    i d go for the swiftec solution!
    credoline's Avatar
    Србија
    I did not try it, but one my friend is and told me that have a problems with car after.
    I still ask for help.
    Problem with car is when car go up the hill, i get DTC P242A readed with Bosch KTS und RPM goes down. And temperature after DPF is higher than before DPF. So i guess that DPF is problem.
    Apr 2012
    wolomin poland
  5. The Following User Says Thank You to lonczyn For This Useful Post:
    credoline (14th July, 2015)
    mihaiservice's Avatar
    http://www.quick-tuning.com
    you can use also this one,dont forget to recode injectors
    pass in PM
    Mike
  7. The Following User Says Thank You to mihaiservice For This Useful Post:
  8. #6
    credoline's Avatar
    Србија
    I do not need to recode injectors, i read ecu via BDM points
