Results 1 to 11 of 11
    bearheroes's Avatar
    Dec 2011
    Default Help to read Tiguan MED17.5.1 internal eeprom with fgtech
    I' trying to read internal eeprom of MED17.5.1 but file i get is 00 00 00....
    When i try via too password tprot reading is unable..Is there any possibility to read?
    Thank you very much.
    I only have EU clone fgtech v54
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    get it with ktag clone easy, sorry fgtech no experience, if you need imo off med17, i can help, ok.
  3. The Following User Says Thank You to x-tech For This Useful Post:
    bearheroes (19th July, 2015)
    bearheroes's Avatar
    Dec 2011
    thanks for your reply and sorry for my late reply...
    Unfortunately i don't have ktag only fgtech and avdi from a friend with license for read/write through boot mode.
    Top Poster + Kanaan's Avatar
    in my car
    with ktag get the same 00 00
    God does not play dice with the universe . (Einstein)
    if anything can go wrong it will . (Morphy laws)
    Jan 2009
    I tried today med17.5.1 with ktag,and also eep all 00 00 00,I have smok and to load good flash and eep , eep size is 32kB, ktag give me 128kB eep
    Any help?
    bearheroes's Avatar
    Dec 2011
    You will never read because there isno eeprom in this ecu...there is emulated eeprom in external flash...post external and internal flash and i’ll give all data
  8. The Following User Says Thank You to bearheroes For This Useful Post:
    robinbga (12th September, 2019)
  9. #7
    Jan 2009
    HM, ktag make full beckup and then ask for fls,eep and mpc to save separetly, I prerss ok and get those 4 files
    I found eep location
  10. #8
    bearheroes's Avatar
    Dec 2011
    vin: WVWZZZ1KZ7B046931
    immo id: VWZ7Z0F8089768
    cs: 88687FB8E14B2D
    mac1: B3BC
    mac2: F23E
    pin: 06950
  11. The Following 4 Users Say Thank You to bearheroes For This Useful Post:
    hesham10 (21st April, 2021), robinbga (12th September, 2019), Stelaras26 (4th February, 2019), ziko (4th February, 2019)
  12. #9
    Oct 2017
    Hello Bearheroes,
    Kindly help me with immo off and immo transfer n off for MED17.5.1.
    Thank you
    Cheers
    Robin B
    Kess V2 . K-Tag
    MiniPro . UPA . VVDI2Attachment 650211
  13. #10
    bearheroes's Avatar
    Dec 2011
    Default Help to read Tiguan MED17.5.1 interna eeprom with fgtech
    I have replied to your pm
  14. #11
    Nov 2019
    hi having same problem on golf 5 gti 1.4
