Old ECU and Smarta damaged by water. Used ECU is not bound
Hi. What is the password? Many thanks.
Hi. What is the password? Thanks.
Hello, i have also a problem with a
tucson 20 0281011690
year: 2004
immo box: 95420-H1000 with 5 pin
Motor D4EA
and i want to make immo off!
File read with kess by obd.
Thanks!
may i ask an immo off for this ecu?
Kia Carens CRD
Bosch: 0281011024
Kia: 39121-27310
do i have to removing the antenna repeater? Where do i find?
Sometimes this ecu when it's hot outside complaining about the camshaft position sensor, (obviosly it's replaced yet) it's seems it's a common error somebody have a repair solution?
thx
hi. Could you switch off immo in my Kia Sorento 2.5CRDI 140HP 2005 year
Eprom 29F400
[ATTACH] 821576[/ATTACH]
Hi !
Please let me know if is possible to disable immo request for this ecu :
0 281 011 115
Hyundai, Santa Fe, 2.0 CRDI Bosch, EDC15C2
in att is flash file.
Thank you for your support !
ECU 028101576 Elentra D2.0 2001
Please if possible, a proven solution.
The car is far.
Thank you.
[QUOTE = knok; 4184574] ¡Hola!
Por favor, avíseme si es posible deshabilitar la solicitud de immo para este ecu:
0 281 011115
en att es un archivo flash.
Gracias por tu apoyo !
Saludos [/ QUOTE]
Your File OFF
Kia Sorento 0281010956
please off
Please help! 100% immo_off. Hyundai Tucson EDC15c7
Thanks!
NEED PASSWORD ? PRESS THANKS AND ADD REPUTATION
edc15c7 0281 010 619 immo off help me accent_orj.rar
