Page 11 of 66 FirstFirst ... 6789101112131415162161 ... LastLast
Results 151 to 165 of 982
  1. #151
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by WinWoj View Post
    OK. Is any sense to upgrade AT91SAM7S256 to higher hw?
    Wont gain much at all..but the timer will drop from 250 to 50 if I recall correctly...better off with 4.01
    its a great programming as is so all you need is some brain power and you are good to go.
  2. #152
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by FxShaw View Post
    i'm not sure i understood correctly 4.01 sw which i use now counting down?? when i assume f...n target 50 should reprog via jling hw and 250 one more time?
  3. #153
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Hardware counting down from 250ish since you have v 4.01...50ish counting down is for v4.74... Stick to what you got.
  4. The Following User Says Thank You to FxShaw For This Useful Post:
    WinWoj (21st July, 2016)
  5. #154
    WinWoj's Avatar
    Jan 2012
    ECU City
    so lower frequency of jlinkin' is using 4.01 ver
  6. #155
    Nov 2015
    anyone can help me ? i need a photo of good A1 that not have problem. i lost A1 cable and now i found a A1 adapter of my friend and now can't connect to car. my carprog original
    i know that this adapter china
  7. #156
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Frankcar View Post
    Yes jumper to pin 16 is correct but r4 or r5 are incorrect search thread and you will see
  8. The Following 2 Users Say Thank You to teerak2uk For This Useful Post:
    Frankcar (21st July, 2016), FxShaw (22nd July, 2016)
  9. #157
    otojm's Avatar
    Feb 2012
    Kepler 22b
    hi,i made my mod like this original pic and it's ok . regards
    (ps: resistor 10k is SMD package code 1002)
  10. The Following 4 Users Say Thank You to otojm For This Useful Post:
    Frankcar (22nd July, 2016), FxShaw (22nd July, 2016), martinracing (14th November, 2017), satalightmad (24th June, 2017)
  11. #158
    Nov 2015
    -Resistance R1 = 10K (103 )
    -Resistance R4 = 10K (103 )
    - R5 = ? Resistance or Capacitor ?
    -Capacitor C2 = 100nf
    -Short Pin 16 OBD to Transistor
  12. #159
    otojm's Avatar
    Feb 2012
    Kepler 22b
    R5= cAPACITOR 100nf
    all Resistance of 10k prefered 1002 (tolerance 1%) so they have more precision than 103 (tolerance 5%).
  13. The Following 2 Users Say Thank You to otojm For This Useful Post:
    Frankcar (27th July, 2016), repairmymodule (19th August, 2016)
  14. #160
    Nov 2015
    i found this link : please see
    http://www.codecard.lt/carprog/carprog-repair-kit-4x-74hc125-4x-22uf-capasitors-1x-mcp2515/prod_566.html
    2x tantalum or electrolytic capacitors for C8 and C9 ( 22?f 16v or 47?f 25v )
  15. #161
    otojm's Avatar
    Feb 2012
    Kepler 22b
    hi i have tantalum 10uf 16v .
  16. #162
    Jul 2016
    can anyone say something about carprog online 8.21 with 9.31 software thats offered on the internet?
    what is the difference between the usuall one and the online version?
    anyone any experiences
    regards
    Gesendet von iPhone mit Tapatalk
  17. #163
    Aug 2016
    thanks was looking for this
  18. #164
    i have a clone car prog 7.28 and its as it came i've used it once or twice on eeprom now i need to clear 01 accord module i dont know pin outs or what pin if needed to power the module it self i have supplies and know how just not much knowledge on car prog help would be awesome
    on a15 adapter what is ground wire car prog keeps saying no device connected but i am using black for ground
    my mistake this module is not on the list so how do i use adapter a17 and do i need the module on the car to proceed ?
    Attachment 398476Attachment 398482
  19. #165
    Jul 2016
    Quote Originally Posted by tamari View Post
    If this module is not listed i dont think that you have a chance to clear
